-   -   Ignition Coil (http://www.jeepforum.com/forum/f11/ignition-coil-1543794/)
BassMasterCHS 07-01-2013 08:18 PM
Ignition Coil
52 Attachment(s)
I need to figure out what grounds attached to the coil bracket, as I had to relocate the coil due to the fact the 88 block I'm using doesn't have a place for the bracket.
BassMasterCHS 07-02-2013 04:07 PM
52 Attachment(s)
Bump
Saudade 07-02-2013 05:44 PM
?? The coil does not attach to the block on an 88.
BassMasterCHS 07-02-2013 05:50 PM
52 Attachment(s)
That's correct, which is why I'm having to relocate it somewhere in my 93..
Saudade 07-02-2013 06:03 PM
Ah. I get it now. You're putting a 88 block into your 93.
I looked in my FSM and don't see a specific ground on the coil. One wire goes to the Dist, the other 2 to the PCM.
On my 88, the coil sits on top of the ignition module mounted on the pass inner fender.
BassMasterCHS 07-02-2013 06:24 PM
52 Attachment(s)
Awesome! Thank you!
The time now is 11:42 AM.
