idling high - JeepForum.com
post #1 of 3 Old 05-05-2008, 02:14 PM Thread Starter
Dannn
idling high
I took my jeep out for the first time today after it say since the beginning of march, i started it up every 2 days during the waiting period and revved it a bit, it ran okay, bit shakey but it was fine after a few miles, i pulled into the parking lot at kroger and put it in park and it was idling at 1500 rpms, hit the gas a bit and it still wouldnt go down, shut it off and start it up again and its around 1000 then drops back down to 600-700...
what gives?
also, how hard is it to put a wheel stud in the rear end? its a 98 limited with a dana 35c
Dannn is offline
post #2 of 3 Old 05-05-2008, 02:21 PM
Crystalship1
Crystalship1's Avatar
Happened to me a couple of years back. I cleared the ECM and all was fine. Pull a battery cable, turn the headlights on, wait 10 minutes, turn lights off, then reconnect the battery cable. Now.... you'll need to DRIVE for 20-30 minutes to allow the ECM "re-learn". Idling won't allow the ECM to re-learn correctly.
Good Luck!!
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
post #3 of 3 Old 05-05-2008, 05:36 PM
wizardPC
I'm running down this problem myself. It's intermittent, and I think it's the root of my 18mpg instead of the low 20's I should be getting.
I cleared the ECM after changing plugs, wires, and air filter. 2 months later, I still have problems with high idle. Last weekend I was going 40mph from a dead stop without ever touching the gas pedal. Put that puppy in neutral and it went to 3 grand on the tach and stayed there.
This weekend, my plans are:
Clean IAC
Clean Throttle Body
Check and Clean Throttle Position Sensor
If that doesn't work, I'm going to replace the forward O2 sensor.
Design previews and mad kid pics on
wizardPC is offline
HELP! Idling, fuel, and no high rpms chadwatson326 XJ Cherokee Technical Forum 3 08-14-2009 04:28 AM
idling too high? xjwheelin XJ Cherokee Technical Forum 8 06-27-2009 12:08 PM
Help Engine is idling high AndyXmud XJ Cherokee Technical Forum 2 06-25-2009 09:58 PM
High Idling on 88 Cherokee MichMarine78 XJ Cherokee Technical Forum 2 11-23-2008 07:14 AM
Idling too high mgriff1969 XJ Cherokee Technical Forum 2 06-01-2005 06:55 PM
