idle problems// backfire// no power on accelaration - JeepForum.com
post #1 of 29 Old 12-06-2010, 04:02 PM Thread Starter
thundering89
1992 XJ Cherokee
hi, i am new to this jeep forum.
I have been having a big problem with my 92 jeep cherokee. sometimes it will idle fine but sometimes it will start sputtering. it has started developing a popping in the intake, such as backfire.
when i put it in gear it begins to pop in the intake manifold really bad and the jeep doesnt go anywhere. i try slamming the gas pedal to the flood but it stays around idle RPMs and continues to sputter.
i have been chasing this problem for a while now. ive read many different threads and ive replaced the basics. plugs, wires, cap, rotor, fuel pump, filter, CPS,
i have a new ECU and new injectors in the mail. they should be here today
can someone give me an idea to what else it could be?
thundering89 is offline
post #2 of 29 Old 12-06-2010, 04:38 PM
hookuspookus
timing chain
hookuspookus is offline
post #3 of 29 Old 12-06-2010, 04:59 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I'd get a fuel pressure gauge on the schrader valve and verify fuel pressure, even though you have replaced the fuel pump. A backfire in the intake can indicate a lean fuel/air mixture. Regulator is still in play.
Your fuel pressure might be okay, but 5 minutes with a fuel pressure gauge will tell you if it is or not. It needs to be ruled in or out early in the troubleshooting process.
Also testing of the MAP sensor would be a good idea as that contributes to fuel/air mixture.
Checking your computer for any stored codes another good idea. Yours is old enough where you can use the key-on, key-off technique to check for those codes.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 29 Old 12-06-2010, 06:37 PM
rafterman45
1994 ZJ
I'm now suffeing from a similar problem. It will idle "ok" once warm, but no power, intake backfire, stall and die
rafterman45 is offline
post #5 of 29 Old 12-06-2010, 06:57 PM Thread Starter
thundering89
1992 XJ Cherokee
i replaced the fuel pressure regulator and the MAP sensor also. i did a compression test on the cylinders to rule out worn valves. each cylinder was between 100 and 110 psi.
i couldnt find my fuel pressure gauge so ill have to run to the shop tomorrow and pick one up.
post #6 of 29 Old 12-06-2010, 11:10 PM Thread Starter
thundering89
1992 XJ Cherokee
i put the new ECU in and nothing. the jeep still runs horrible.
the next thing is checking the fuel pressure and timing chain.
is there any way to adjust the timing on a 92 cherokee?
post #7 of 29 Old 12-07-2010, 02:51 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Test the Throttle Position Sensor and the O2 sensors.
For the HO years, 91-02, the O2 sensor has 4 wires. One wire is the 12-14 volt power that comes from the O2 sensor heater relay on the passenger side firewall (unless they moved them in later years to the relay & fuse boxes?), and that powers the internal heater in the sensor so that the sensor can work at idle, and almost immedietly after start up. Loss of that power will hurt gas mileage even with a good O2 sensor.
Two black wires are grounds for the heater power and O2 signal to the ECU. A poor ground will limit current to the O2 sensors heater or cause an error in the O2 sensor output voltage read by the PCM (ECU) causing poor mileage even with a good O2 sensor. Test the 2 ground wires with power off. Test between the wire end at the sensor and the battery negative ground post. It should read less than 1 ohm.
The last wire, #4, is a signal feed wire, 0-1 volts, from the O2 sensor to the PCM (ECU) sensor. The O2 sensor is an O2 concentration sensitive variable voltage generator. At optimal O2 concentration the O2 sensor puts out 0.45 volts.
At idle that voltage should read 0.1-0.9 volts oscillating quickly back and forth roughly once every second. At 2000 rpm it should run between 0.4 and 0.5 volts max (in park). A digital meter can NOT be used for reading the O2 sensor voltage, but it can be used to test the grounds and the 12-14 volts to the heater. You must use an old style analog meter with the needle gauge on the display to see the voltage swing back and forth.
If the O2 sensor readings are not right, say they read .1 volts or .8 volts steady, you have a problem. BUT before you blame the O2 sensor make sure it has good wiring, and make sure the proper voltage is feeding it, by turning power on, engine off to read the engine off voltage feeds (12-14 on one, and ensure the ground wires (power off) reads less than 1 ohm to the battery negative post.
If any one of the grounds or the O2 sensor to ECU/PCM wires reads a high voltage chances are the wiring harness is damaged and the 12-14 volts for the O2 sensor heater is getting through a bad spot in the wires insulation and contacting a ground wire or the O2 sensor wire feed to the ECU/PCM. This is not the O2 sensors fault, but a wiring problem.
A leaky exhaust system or leaky fuel injector(s), or bad compression or leaky valves, bad plugs, wires, cap, rotor, HV coil, and so on, or combination of these, can also cause a lean or rich condition that gives you high or low O2 sensor readings that are not the O2 sensors fault, so try and verify those other items also before buying parts like an O2 sensor to fix your problem.
CJ7-Tim is offline
post #8 of 29 Old 12-08-2010, 02:02 AM Thread Starter
thundering89
1992 XJ Cherokee
checked everything. timing looks good. no worn cam lobes. hooked up the car to the modis scan tool and all sensors working good. still waiting for the injectors to get her. it idles fine and runs good before 1500 rpm, once you get to 1500 rpm or more it starts popping real bad in the intake.
This problem is boggling my mind.
post #9 of 29 Old 12-08-2010, 04:30 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have you checked the fuel pressure yet?
cruiser54 is offline
post #10 of 29 Old 12-08-2010, 10:41 AM Thread Starter
thundering89
1992 XJ Cherokee
fuel pressure at 15 psi. the range for my jeep is 12 to 15, so it is good
post #11 of 29 Old 12-08-2010, 05:01 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Where in the world did you come up with that spec for your fuel pressure?
It should be in the high 30s.
post #12 of 29 Old 12-08-2010, 05:27 PM
Topgun514
1988 XJ Cherokee
I had the same problem, my TPS had been installed by some idiot (Myself) and the sensor was not underneath the throttle jam itself. I would check your TPS first.
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #13 of 29 Old 12-08-2010, 05:38 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You would check the TPS first when he has only 15 PSI of fuel pressure and 31 to 39 is required?
post #14 of 29 Old 12-08-2010, 05:42 PM
tjwalker
tjwalker's Avatar
Cruiser is right on.
I believe that the fuel pressure at idle should be approx. 31 psi.
If you don't have these numbers, STOP and resolve this!
tjwalker is offline
post #15 of 29 Old 12-08-2010, 06:05 PM Thread Starter
thundering89
1992 XJ Cherokee
woops. i was looking at the wrong section
89 Cherokee 4.0 severe power loss & backfire! mondojeep XJ Cherokee Technical Forum 16 06-05-2014 10:08 AM
no vac leaks - backfire, rough idle, fast idle, slow response alhefner XJ Cherokee Technical Forum 7 09-16-2009 12:58 AM
Hesitation, backfire, rough idle?? khurley XJ Cherokee Technical Forum 9 05-23-2009 02:21 PM
Stroker swap, rough idle, backfire, loud sucking noise from intake ttocsnekia XJ Cherokee Technical Forum 3 02-25-2009 06:33 AM
Power Loss/ Low Idle blakdot XJ Cherokee Technical Forum 1 04-26-2008 03:17 PM
