idle issue still - JeepForum.com
post #1 of 9 Old 12-24-2009, 05:10 PM Thread Starter
Willy36
1990 XJ Cherokee
idle issue still
I had already started a thread related to this but misjudged what the cause was at that point.
Recently I've been having an issue where the first one or two times I come to a stop when the engine's cold, the idle will drop down to like 300 RPM and sound like it's going to die, but it always comes back up to normal every time. By the third or fourth time I come to a stop this doesn't happen even when the engine is still very cold (below the 100 mark). At the same time an issue started where before the engine would come up to 210, it would lack serious power and hesitate. I cleaned the hell out of the TB and now the power issue went away, but the idle issue is still there. Here's what I know for sure:
1. TB, including IAC, can not possibly be any cleaner than it is.
2. TPS, Coolant Temp Sensor, CKP are all good.
3. Air filter is very clean
4. Entire ignition system checks out visually and was just replaced about a year and a half ago (maybe 10,000 miles ago)
5. Fuel system has pressure and the fuel filter is less than 6 months old.
6. From what I can tell without taking the rocker cover off, the valvetrain (at least what can be seen through the oil fill hole) is very clean.
7. The MAP sensor reads 3.55 volts when it's supposed to read 4-5 but I think this may be because I'm currently at 7500 feet elevation so the air's a bit thin.
Before I go throwing any more money that I don't really have at it, can someone give me some good suggestions on what to check?
Willy36 is offline
post #2 of 9 Old 12-24-2009, 05:29 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Brainstorming here....how about EGR? I believe your 1990 has this.
You shouldn't have egr function at idle if I remember right; it's been a while since I worked on one of those. But I remember them being susceptible to carbon build up which could leave the valve on when it should be off. And they can cause idle issues.
Renix guys, please chime in!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 9 Old 12-24-2009, 05:54 PM
maddzz
1989 MJ Comanche
Have you tried adjusting the IAC? You could also have damaged the pintle (I think what you call it) on the IAC when you cleaned it.
maddzz is offline
post #4 of 9 Old 12-25-2009, 12:02 AM Thread Starter
Willy36
1990 XJ Cherokee
Ooh hadn't thought of that. I'll be sure to check that tomorrow if I get a chance. Thanks
I was unaware the IAC was adjustable, could you please tell me how to do that?
Willy36 is offline
post #5 of 9 Old 12-25-2009, 07:28 AM
tjwalker
tjwalker's Avatar
Idle air control is not adjustable.
tjwalker is offline
post #6 of 9 Old 12-26-2009, 05:07 PM Thread Starter
Willy36
1990 XJ Cherokee
Ok should be 2nd to last update on this issue for anyone else who may experience this problem:
After messing with and taking off and inspecting the EGR valve, I can almost 100% for sure say this is the problem. It sticks, but only just slightly and only when cold. This would seem to explain my symptoms perfectly. When the new one comes in in a week, I'll post up for sure.
tjwalker, thanks a ton for all your help
Willy36 is offline
post #7 of 9 Old 12-27-2009, 06:49 AM
tjwalker
tjwalker's Avatar
Glad I could help.
Be sure to let us know if the new EGR valve completely cleans up your symptoms.
tjwalker is offline
post #8 of 9 Old 01-03-2010, 01:35 PM Thread Starter
Willy36
1990 XJ Cherokee
Final update: New EGR valve is finally on and all the issues have cleared up
Made my mileage go up a tad too.
Willy36 is offline
post #9 of 9 Old 01-03-2010, 01:47 PM
99Greenmachine
JF is on a roll with getting solutions to the problems today
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
Idle issue verbalkint99 XJ Cherokee Technical Forum 2 08-25-2009 03:32 PM
need help with fast idle issue pistilnoon XJ Cherokee Technical Forum 10 12-22-2008 07:00 AM
XJ Idle issue! Traxion XJ Cherokee Technical Forum 2 04-09-2008 12:37 PM
Another Comanche Issue. . . Idle 97_4popper XJ Cherokee Technical Forum 5 03-21-2006 07:22 AM
Another Comanche Issue. . . Idle 97_4popper MJ Comanche Technical Forum 3 03-21-2006 07:21 AM
