idle issue after changing exhaust manifold - JeepForum.com
post #1 of 7 Old 07-25-2013, 03:08 PM Thread Starter
sreilly1
1999 FSJ Cherokee
Ok, i know i probably screwed something up. I just finished replacing the exhaust manifold on my 99 Cherokee 4.0, which of course meant i had to remove the intake manifold, power steering pump and electric fan to do it. I put everything back together and now when i start the motor it immediately wants to red line, so i shut other down. I double checked all my electrical connections and they look good. Any idea what is wrong?
sreilly1 is offline
post #2 of 7 Old 07-25-2013, 04:32 PM
Holder350
1995 XJ Cherokee
With the motor running that fast it has to be getting air from somewhere. Double check the throttle body. Make sure there is nothing holding the throttle plate open.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 7 Old 07-25-2013, 04:37 PM
miceanic
1990 XJ Cherokee
Recheck all the manifold bolts, might have missed one so the intake is sucking in lots of air
miceanic is offline
post #4 of 7 Old 07-25-2013, 05:20 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Those are common symptoms of incorrectly re-installing the intake manifold. There is a massive air leak at the intake manifold gasket.
You will have to unbolt the intake manifold, and re-seat it square and flush to the head. If necessary, run a drill bit into the holes the dowel pins fit into to clean them up and make them slightly larger.
CJ7-Tim is offline
post #5 of 7 Old 07-25-2013, 05:21 PM
Glavus
I just recently changed my cracked manifold, I got everything together and it immediately red lined when I started her up.
I took off the intake and tried putting it on again, and that fixed my issue.
Glavus is offline
post #6 of 7 Old 07-25-2013, 06:23 PM Thread Starter
sreilly1
1999 FSJ Cherokee
Thanks guys. I looked some more with a mirror and found the pins were not lined up. Got them lined up now and just snug. Will finish tomorrow and let you know how it goes.
sreilly1 is offline
post #7 of 7 Old 07-27-2013, 11:07 AM Thread Starter
sreilly1
1999 FSJ Cherokee
Amazing what happens when get the pins lined up. Hour or so to get it together but its done and working perfect. Thanks again.
sreilly1 is offline
exhaust , idle , intake , manifold , timing
