Quantcast Ideas for reverse light? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Ideas for reverse light?
Old 04-04-2007, 08:16 PM   #1
Topgun514
1988 XJ Cherokee
I thought reverse lights were dumb the first time i saw them but when i finished my lift, my stock reverse lights blew i realized in the driveway
and on trails im blind at night...
heres my idea:
I have one BIG light that i know can illuminate, but i hate the under rear bumper look and it looks like it would get torn if i dropped off something
On my back left side where the the plastic bumper corner is, im gonna take off and cut the bumper the length of around 7 inches except the bottom section, set the light with the bolt coming down and wallah!!!
maybe put the plastic cover on and cut a hole around it
any ideas and input please can be needed, as this may be a bad idea
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline   Reply With Quote
Old 04-04-2007, 08:24 PM   #2
xwildman138x
1995 XJ Cherokee
that sounds like a great idea, when you get it done you gotta post some pics!!!
"Yo ho yo ho a pirate's life for me"
Tire Carrier
Ma & Pa's Rig
xwildman138x is offline   Reply With Quote
Old 04-04-2007, 08:58 PM   #3
99Xjeep
GoJeep did this. He put the lights on each side of license plate.
http://www.go.jeep-xj.info/Exterior.htm
99Xjeep
Previous-
96 Classic
74CJ5
Dip it, Tip it, Flip it back over
99Xjeep is offline   Reply With Quote
Old 04-04-2007, 09:00 PM   #4
99Xjeep
Here is the write up
http://www.go.jeep-xj.info/HowtoReverseLights.htm
99Xjeep
Previous-
96 Classic
74CJ5
Old 04-04-2007, 09:13 PM   #5
nudosimmons
someone a while back posted some info about a high power bulb that fit in the factory tail light. anyone know of the bulb? name and general info?
1988 xj 4.0, ba-10, np231
trimmed fenders
3in lift, 33s
herculinded interior
custom bumper
http://www.jeepforum.com/forum/f11/update-my-xj-362812/
nudosimmons is offline   Reply With Quote
Old 04-04-2007, 09:18 PM   #6
severous01
i cut 2 2x4" holes in the rear bumper and mounted my "fog" lights in the bumper. i made some mud shields out of some scrap sheet i had laying around and bolted them to the same mounting holes i put the lights in. all i did for the shields was bend the sheets into a semi-l semi-c shape and cut a hole in the bottom...wired into a switch with speaker wire and vwa-la...nice 55w reverse lights.
nice....but i didnt 'primer' the bumper and now i have a little rust since the 6-monts of salt/road/mud debris i've left on there...no problem since i'm looking at a new bumper any way...and when i find out what i want i'll cut the same holes in the bumper but this time i'm wiring into a seperate relay and into a switch and then i'll herculiner the rear bumper.
severous01 is offline   Reply With Quote
Old 04-04-2007, 10:50 PM   #7
madrabbitt
link to ebay auction
I had bought a 2 pack from that seller, but they sent me the wedge type instead of the 1156 base cherokees use, ended up installing them on my dad's yukon.
Later, i got the ones for the cherokee from pep boys.
not a HUGE improvement over stock, you may be dissapointed, but its 14 bucks for the two pack.
I have hella 55 watt work lights on the rear of mine under the bumper.
same ones tractors and bobcats have mounted.
Rugged little things, bright, and nice beam pattern, i broke one down in el paso when i backed into a solid rock/earth berm... which is why i originally got 4... 2 spares.
After looking at the housing, i considered cutting square holes in my rear bumper, and mounting them in there... only problem is the bumper isnt a flat surface.
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 04-04-2007, 11:27 PM   #8
drew and not u
I had similar issues, and just mounted a couple cheap wal-mart lights on the aft crossbar:
my xj
"I Feel Sorry For Jeeps that Don't Go Off-Road" Facebook Group
<- specs go over there, man!
drew and not u is offline   Reply With Quote
Old 04-05-2007, 04:12 PM   #9
supes82
1994 XJ Cherokee
Here is what I did with mine
I wired them into my stock back-up lights so they come on when i throw it in reverse.
Curtis
TO ALCOHOL! The cause of, and solution to, all of lifes problems!
RED JEEP CLUB MEMBER #395
supes82 is offline   Reply With Quote
Old 04-05-2007, 05:21 PM   #10
TXjeep97
I'm also looking into cutting the rear bumper and mounting some tractor lights in there. As mentioned above though, it isn't flat. No biggie. I will also be getting some up on a roof rack (when I get it), but they will be more like "work" lights than reverse lights.
TXjeep97 is offline   Reply With Quote
Old 04-05-2007, 05:39 PM   #11
87bucket
im going to put some aux lights in my hatch, pretty close to where the speaker goes. i gonna use the grommet fit semi stye, however, i assume you have a 97..so because you have a metal hatch im not sure if yours has space for the lights im talking about, or if you have hatch or soundbar speakers, or...whatever else. anyways, just food for thought.
94 4-door, 4.0, AX-15, NP231, Chryco 8 1/4, 2" BB, 30x9.5 Kumho MT's
87bucket is offline   Reply With Quote
Old 04-05-2007, 06:30 PM   #12
TXjeep97
I like the idea about the lights being mounted by the license plate, but I can't find any that are bright enough.
Old 04-05-2007, 06:37 PM   #13
severous01
hella ff75 and hella ff50 foggers. they're bright as anything else on the market...and they're cheap.
or, the "baja" lights in a FOG pattern.
basicly any small light in a fog pattern.
Glock Forum
