Quantcast I swear I searched...need TCase drop bolt size and a little help, pronto! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > I swear I searched...need TCase drop bolt size and a little help, pronto!
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 04-17-2009, 10:47 PM   #1
LandRover
I've been all over the google and the forum and what-not. I can't find a definitive answer. I want to get a TCase drop done this weekend...I have made spacers, and I bought bolts, but I didn't realize that there's nut inserts up there in the frame rail. Should have asked first.
I have one nut and one bolt head looking at me...I guess that means one is a post threaded into the threaded hole in the subframe? Getting that out is easy enough... I bought nuts and bolts thinking that I was replacing everything, but they're not metric, and the threads don't match...
So, what is the bolt size? I assume they're metric? I got length figured out, I just need the width/thread count.
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Maxxis Bighorn 32's
LandRover is offline   Reply With Quote
Old 04-17-2009, 11:18 PM   #2
XJK
The Guru of Nothing
XJK's Avatar
IIRC they are 10mm with standard pitch 1.5 somebody verify.
XJK is offline   Reply With Quote
Old 04-17-2009, 11:20 PM   #3
Contra
not sure, just take 1 out and go to the auto store, or Home Depot/Lowes
Ever Gone Geocaching?
Opencaching
Contra is offline   Reply With Quote
Old 04-17-2009, 11:47 PM   #4
JeepRide
Take one of your nut's off and take it somewhere and have it's thread's matched.
98 xj 4.0L 231 t\case off road commode
4 in the floor and a fifth under the seat
Eat more possum
JeepRide is offline   Reply With Quote
Old 04-17-2009, 11:54 PM   #5
clrusty
1987 XJ Cherokee
when i dropped my t-case i went to ace and they hooked me right up, the stud bolts come out. i replaced them with bolts too. good luck..
clrusty is offline   Reply With Quote
Old 04-18-2009, 02:44 AM   #6
drvn93
1995 XJ Cherokee
it should be 10m x 1.5 x 50mm grade 8
what did you use to make the spacers?
drvn93 is offline   Reply With Quote
Old 04-18-2009, 07:33 AM   #7
skyway0018746
i used 3/8 18 went in fine and you can get actual grade 8 too
skyway0018746 is offline   Reply With Quote
Old 04-18-2009, 08:27 AM   #8
foggybottombob
I heart bacon and pie
foggybottombob's Avatar
When you make the change, do ONE SIDE AT A TIME. If you take the bolts out of both sides at the same time you will have a hard time getting the cross member lined up with the holes again.
foggybottombob is online now   Reply With Quote
Old 04-18-2009, 09:18 AM   #9
tangofox007
There are no "Grade 8" metric fasteners.
tangofox007 is offline   Reply With Quote
Old 04-18-2009, 04:42 PM   #10
LandRover
Thanks for the help and advice guys. I made the spacers out of 1.25"x2.25" inch rectangular steel tubing. Some flat black krylon and I'm good to go... I don't think my local Ace has metric stuff I'll have to try someplace else. I went in there with one of the bolts the first time and couldn't find anything that I could thread it into...
I actually bought some 3/8 bolts, but I was scared to destroy the threaded holes in the frame. I'll go this route if I can't find anything locally.
Thanks again
RHD '98 XJ
Old 04-22-2009, 12:45 AM   #11
drvn93
1995 XJ Cherokee
you are right .. I guess I mean the equivlent. which I think would be 10.9
try fastenal if you have them nearby...the one near me said they can order them in in a day or 2
Old 04-22-2009, 09:35 AM   #12
LandRover
Found some at Napa Auto...did the drop last night. Thanks guys. They are 10mm, for future reference. The dumb posts came out with vice grips and patience.
BUT the stock ones seem slightly tapered or something... could just be bad threads, but a 10mm nut with what has to be the right thread count threads on to the stock bolt easily, but gets really tough to thread at about 1/2 way...way after it would get difficult if the threads were wrong. Weird.
Anyway, the new bolts threaded in to the frame rail fine...a bit tight, but that's probably just some gunk in the threads. Haven't driven on it yet...rode my bike to work. I'm hoping it kills my little vibes.
RHD '98 XJ
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
