I searched first. A different bumper question. - JeepForum.com
post #1 of 2 Old 04-17-2009, 10:24 AM Thread Starter
CherokeeOwner
Yes, I searched first. I cannot find what I want so I ask,
I have been looking for a rear bumper that will allow me to keep my end caps.
I'm also looking for a front bumper that wraps around the side and is the same width as my endcaps. I don't like the look of the truck with a big gap were the end caps were.
Pictures of my XJ with the stock bumpers.
CherokeeOwner is offline
post #2 of 2 Old 04-17-2009, 11:08 AM
gijazbo
For the rears there are a lot of companies that make bumpers that fill in that cap. It would be hard to use the 97+ end caps with an aftermarket bumper.
http://logansmetals4x4.com/id8.html
http://www.jeep4x4center.com/product...?number=WAR563
http://www.jeepinoutfitters.com/scri...p?idproduct=42
Rigidco...
http://www.rigidco.com
/FbG.htm
you get the idea just search around. As for the front.
This is AJs armor.... he can customize anything you want changed or added.
http://www.ajsoffroadarmor.com/image...hatxj03-lg.jpg
Rigidco...
/FbG.htm
however, the rear you could get a cheaper bumper(basicly just C-chanel and use the pre-97 endcaps.
Something like this ... the same manufacturer makes an identical rear bumper that the older end caps can fit on with a little tweaking.
http://cgi.ebay.com/ebaymotors/Jeep-...Q5fAccessories
maybe this helps
It sucks to own a jeep in NE Ohio
MOPAR.... Made Of Paper clips And Rubber bands
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
My build thread:
gijazbo is offline
Airbag question and a distributor modification question! (i searched) Jameslol XJ Cherokee Technical Forum 2 05-11-2008 02:08 PM
yes, I searched: JCR front bumper install JW 4x4 XJ Cherokee Technical Forum 3 07-30-2007 08:49 AM
Bumper Bracket...searched and still confused Jeepthing88 XJ Cherokee Technical Forum 6 01-24-2007 02:37 PM
Searched and Searched Cant find any info about Tomken Lifts,good or bad savage1978 XJ Cherokee Technical Forum 8 11-07-2005 02:23 PM
Another BB question.......yes I searched mdoug445 XJ Cherokee Technical Forum 2 02-21-2005 12:57 PM
