I searched but still can't find, about a cam shaft!? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > I searched but still can't find, about a cam shaft!?
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-11-2006, 01:44 AM   #1
devile
Ok, i have a 1991 Jeep cherokee that has a 3" lift... and is ognna be a DD, no trails or anything hardcore... So im gonna do some preformance upgrades such as, cold air intake, high flow exhaust, and i'm gonna do a top end rebuild because of the ticking and other noises... (Rebuild head, new lifters, push rods...) and here is my Question. Has anybody put a preformance cam shaft in their jeep? If so let me know if it's worth the money, and what i should be looking for. Thanks...
98' XJ Sport 4.0, Unknown Lift, Bushwackers, 33X12.5R15, AW4, NP231
devile is offline   Reply With Quote Quick reply to this message
Unread 02-11-2006, 10:42 AM   #2
XJ4oh
1997 XJ Cherokee
Theres a few companies that have performance cam's for the 4.0. If your going to do a top end rebuild and you plan on adding a cam, definatly have the head ported and polished to take advantage of the cam, it would be a minimal gain without doing that. Try www.summitracing.com i've seen 4 or 5 on there. You can also try www.jeepsunlimited.com/forums and go into the "Speedfreaks" section, they can actually set you up with the perfect cam for your needs.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline   Reply With Quote Quick reply to this message
Unread 02-11-2006, 10:57 AM   #3
whitexj88
http://www.cranecams.com/index.php?s...243-258%20C.I.
whitexj88 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2006, 11:39 AM   #4
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Go over to Jeeps Unlimited's Speed Freak board and ask Dino about cam profiles for the 4.0. I had asked him at one point and he said you can get some good gains out of a cam. I just can't remember what manufacturer and profile he said to use.
Derpy Hooves for President in 2012
Matt Gertsch is offline   Reply With Quote Quick reply to this message
Unread 02-11-2006, 01:08 PM   #5
Voyager
When I needed a replacement cam for my 1990 the mechanic (someone I trust completely) advised against it. He simply said the performance gain wasn't worth the extra $ and I would get better and longer service from a stock replacement. But maybe you're looking to go more extreme than I was.
It's not a mudder, it's a snowmobile. OK, maybe a little mud.
1990 Cherokee Pioneer (oxymoron) 4wd, 4.0
Liberators, Harbor Freight lights, Silverstars, Flowmaster, K&N home made intake, other generic improvements.
Voyager is offline   Reply With Quote Quick reply to this message
Unread 02-11-2006, 03:34 PM   #6
LEAD_NOT_FOLLOW
1989 XJ Cherokee
I have a comp cam, aswell as comp rockers and lifters.
LEAD_NOT_FOLLOW is offline   Reply With Quote Quick reply to this message
Unread 02-11-2006, 04:05 PM   #7
XJ4oh
1997 XJ Cherokee
Uhh.. I dont know about that. Cams are between $90 and $130 for what ive seen for the 4.0, thats really not much money for a true performance gain. It wont be huge but it will help, and there will be an improvment, especially with added headwork like I suggested. There is no reason why a different cam (as long as its new, with correct lifters and such) will be less reliable than a stock cam. It will last just as long, as long as it was put together right.
Baja Aux. Lighting.
Unread 02-11-2006, 04:25 PM   #8
JeepsterLR
Dino Savva's various websites have about as much info available as you can find anywhere on the net about performance for the 4.0.
http://www.angelfire.com/my/fan/Jeep4.0Camshafts.htm
http://www.jeep4.0performance.4mg.com/
JeepsterLR is offline   Reply With Quote Quick reply to this message
