I searched but still can't find, about a cam shaft!? - JeepForum.com
post #1 of 8 Old 02-11-2006, 12:44 AM Thread Starter
devile
devile's Avatar
Ok, i have a 1991 Jeep cherokee that has a 3" lift... and is ognna be a DD, no trails or anything hardcore... So im gonna do some preformance upgrades such as, cold air intake, high flow exhaust, and i'm gonna do a top end rebuild because of the ticking and other noises... (Rebuild head, new lifters, push rods...) and here is my Question. Has anybody put a preformance cam shaft in their jeep? If so let me know if it's worth the money, and what i should be looking for. Thanks...
98' XJ Sport 4.0, Unknown Lift, Bushwackers, 33X12.5R15, AW4, NP231
devile is offline
post #2 of 8 Old 02-11-2006, 09:42 AM
XJ4oh
1997 XJ Cherokee
Theres a few companies that have performance cam's for the 4.0. If your going to do a top end rebuild and you plan on adding a cam, definatly have the head ported and polished to take advantage of the cam, it would be a minimal gain without doing that. Try www.summitracing.com i've seen 4 or 5 on there. You can also try www.jeepsunlimited.com/forums and go into the "Speedfreaks" section, they can actually set you up with the perfect cam for your needs.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #3 of 8 Old 02-11-2006, 09:57 AM
whitexj88
whitexj88 is offline
post #4 of 8 Old 02-11-2006, 10:39 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Go over to Jeeps Unlimited's Speed Freak board and ask Dino about cam profiles for the 4.0. I had asked him at one point and he said you can get some good gains out of a cam. I just can't remember what manufacturer and profile he said to use.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #5 of 8 Old 02-11-2006, 12:08 PM
Voyager
When I needed a replacement cam for my 1990 the mechanic (someone I trust completely) advised against it. He simply said the performance gain wasn't worth the extra $ and I would get better and longer service from a stock replacement. But maybe you're looking to go more extreme than I was.
It's not a mudder, it's a snowmobile. OK, maybe a little mud.
1990 Cherokee Pioneer (oxymoron) 4wd, 4.0
Liberators, Harbor Freight lights, Silverstars, Flowmaster, K&N home made intake, other generic improvements.
Voyager is offline
post #6 of 8 Old 02-11-2006, 02:34 PM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
I have a comp cam, aswell as comp rockers and lifters.
LEAD_NOT_FOLLOW is offline
post #7 of 8 Old 02-11-2006, 03:05 PM
XJ4oh
1997 XJ Cherokee
Uhh.. I dont know about that. Cams are between $90 and $130 for what ive seen for the 4.0, thats really not much money for a true performance gain. It wont be huge but it will help, and there will be an improvment, especially with added headwork like I suggested. There is no reason why a different cam (as long as its new, with correct lifters and such) will be less reliable than a stock cam. It will last just as long, as long as it was put together right.
Baja Aux. Lighting.
XJ4oh is offline
post #8 of 8 Old 02-11-2006, 03:25 PM
JeepsterLR
Dino Savva's various websites have about as much info available as you can find anywhere on the net about performance for the 4.0.
http://www.angelfire.com/my/fan/Jeep4.0Camshafts.htm
http://www.jeep4.0performance.4mg.com/
JeepsterLR is offline
Cant find axle shaft seals for the life of me. fitbmxseries1 XJ Cherokee Technical Forum 16 06-17-2009 08:35 PM
Searched and couldnt find what I needed.(RC 3" lift and Rusty 3.5 leafs) AustinTexasXJ XJ Cherokee Technical Forum 6 03-23-2009 07:52 PM
ive searched for 10 days and cannot find my engine swap answer.. coalregionXJ XJ Cherokee Technical Forum 7 02-26-2009 02:10 PM
Where to find front shaft bolts? Overdrive XJ Cherokee Technical Forum 2 04-13-2006 02:05 PM
Searched and Searched Cant find any info about Tomken Lifts,good or bad savage1978 XJ Cherokee Technical Forum 8 11-07-2005 02:23 PM
