I own a '95 XJ Inline 6 4X4 and I'm having a problem. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > I own a '95 XJ Inline 6 4X4 and I'm having a problem.
Unread 06-05-2012, 02:30 PM   #1
DefJeep
I own a '95 XJ Inline 6 4X4 and I'm having a problem behind the clutch fan. The bearings went out this morning and now I'm trying to find the part and I don't know the part name. Everyone tells me it's the water pump but the water pump is on the other side of the motor. I was told it was something like the idler but still can't find any parts with "idler" in the name. PLEASE HELP!
DefJeep is offline   Reply With Quote Quick reply to this message
Unread 06-05-2012, 03:03 PM   #2
440_Magnum
http://www.factorychryslerparts.com/products/JEEP/1995/CHEROKEE40L-I6-Power-Tech--4-Speed-Automatic-AW4/BRACKET--BRACKET-ASSEMBLY---BRACKET--AC-and-Alternator-Idler-Mtg-40L-Engine--40L-Engine-1994-95--40L-Engine--wAir-LHD/4585117/53006548.html
Expensive bugger, the one for non-AC jeeps is only $90. Might see if there's a way to press a new bearing into the existing bracket- I sense an aftermarket equipment opportunity there!
2011 Grand Cherokee Laredo 4x2, 3.6 Pentastar
1999 Cherokee 2door 4x4 5-speed (daughter's)
Two big-block Mopars, Challenger SRT8, and a Ram 1500
2001 Cherokee Sport automatic 4x2 (sold)
440_Magnum is offline   Reply With Quote Quick reply to this message
Unread 06-05-2012, 03:25 PM   #3
kg4kzv
1995 XJ Cherokee
Yeah buddy, I think if mine goes out I'll either be looking for a way to bypass it and go electric or hitting the junk yards.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline   Reply With Quote Quick reply to this message
Unread 06-06-2012, 09:04 AM   #4
440_Magnum
Chris
I can't believe someone doesn't make a kit to replace the bearing, or else offer a service to send in a core and they send you back a bracket where they've replaced the bearing. Maybe the darn things just live longer than the rest of the engine, statistically. They are pretty beefy for just a small fan.
Unread 06-06-2012, 03:21 PM   #5
kg4kzv
1995 XJ Cherokee
This got me to thinking. Has anyone that converted to an electric fan been able to bypass this expensive crazy little doodad.
I know when I was in my Mustang fad people would post diagrams in how to reroute the accessory drive belt to remove certain things. Does such a thing exist for 4.0 Jeeps?
One could buy a real nice electric fan ,fan controller and a few cases of beer for what that that thing cost.
Chris
'95 , clutch fan , inline , jeep , xj
