I need pics, wright up for trimming fenders front and rear
#1 | |
I need to see some pics or a wright up on how to cut and fold the rear fenders, like where to cut, I also am going to trim my front fenders, so what is the cleanest way to do that, jig saw, grinder with cutoff wheel, or can I cut and fold the front. I am going to be running 31's on 2in . Thanks. micah
95 YJ on 36's |
#2 |
use a jig saw it works way way better i did mine. with a jig saw heres a pic of it.
#3 |
The Guru of Nothing
from the tech/faq sticky
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#4 |
thanks kyle, that helped, I forgot to look in the sticky, those are good wright ups, what is the cut and fold in the rear I always read about. and who sells the rubber molding other than Rock Lizard Fab. and has anyone else kept there stock fender well liners. Thanks micah
95 YJ on 36's |
#5 |
The Guru of Nothing
here are a couple links regarding cut and fold
http://www.jeepforum.com/forum/showthread.php?t=92738&highlight=cutting+rear+quar ter+panel http://www.jeepforum.com/forum/f11/cut-fold-diagram-300251/ -Kyle
#6 |
The edge molding you can get at Advance Auto Parts. It's just door edge trim. Cut and fold in the back is pretty straight forward. You just make some relief cuts between the spot welds up to the "flare out" portion of the metal, and pound the tabs up and in. I used a ball peen hammer, the rounded end worked well for forming them tightly once they were folded up all the way.
If you have access to an air nibbler, it's the way to go. Smooth easy cuts all along the jeep. The relief cuts in the back turn out nice too...they're wide enough that they don't bind while folding. Here's a decent write up...I haven't looked to see if someone else linked it already though - http://www.jeepforum.com/forum/f11/fender-trimming-write-up-395952/?highlight=fender+trimming
'99 Sport...Custom Front & Rear Bumpers, Rusty's Air Tube, Dynomax Exhaust, Hacked Fenders, Cut 'n Fold Rear Quarters, Durabak'ed Fenders-Rockers-Doors, OME 2" & 265/75R16 Kumho's, Silverstars w/ Upgraded Harness SOLD
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
