i need a head liner for my 98 - JeepForum.com
post #1 of 21 Old 03-19-2009, 06:44 PM Thread Starter
mhall101
i cant find a head liner for my 98 xj 2dr, i need a new unit. Mine was burnt
They dont make them any more so any help would be great
mhall101 is offline
post #2 of 21 Old 03-19-2009, 06:55 PM
jebmccall
1997 XJ Cherokee
id try a collision shop, id consider that bofy work. my buddy got his done for a hundred bucks.
jebmccall is offline
post #3 of 21 Old 03-19-2009, 07:22 PM
XJohnnyC
XJohnnyC's Avatar
I have the one from my 98 2-door in perfect condition. You can have it for free if you come pick it up. Sorry.
XJohnnyC is offline
post #4 of 21 Old 03-19-2009, 07:40 PM
MSH5337
MSH5337's Avatar
Just buy some matching fabric and glue that puppy up there!
2001 Amber Fire TJ
1989 Wagoneer Limited. 4X4
MSH5337 is offline
post #5 of 21 Old 03-19-2009, 10:35 PM
dapsteez
1992 XJ Cherokee
Find someone local parting out a Cherokee--that seems like the most reasonable option. I just replaced my headliner fabric last week btw. A bit of a pain, but so worth it in the end...
dapsteez is offline
post #6 of 21 Old 03-19-2009, 10:50 PM
filluptrk
I did my 83 Ford Ranger with the sponge back headliner material I got from a local Hancock Fabrics. The ranger has a cardboard backing that I cleaned up, sprayed some 3M adhesive by the instructions on the can and it worked perfect. It has been on for years and is still good.
That said I have no idea of how the Jeep is done, but if it uses the same cardboard liner base and you can get hold of one you can do the same I did. It is not hard to do, just don't press hard on the actual liner material or you will get a lumpy look or worse adhesive spotting through the liner. Just go gently the adhesive will hold it perfectly with a light touch.
If you have a good fabric store they will have the stuff, or know how to get it. Should not be that expensive. Phil
filluptrk is offline
post #7 of 21 Old 03-20-2009, 04:08 AM
Hunterdad
2005 WK
Just curious, what steps did you take for replacing the headliner?
ao lot Quan ao thoi trang dep Thoi trang cho be Chup anh nghe thuat cho be Quan ao Ban buon Ban buon
Thanks
Adam
2005 WK 3.7L | RC 2"BB | Monroe LL | 265-70-17 Goodyear Wrangler AT/S | 1.25" TeraFlex Spacers
Hunterdad is offline
post #8 of 21 Old 03-20-2009, 09:00 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The headliner for a 2 door should be the same as one for a 4 door. Drop by the junkyard and look around for one. You will spend less time looking for good used one than you will spend trying to refurbished a damaged one.
Try www.car-part.com
CJ7-Tim is offline
post #9 of 21 Old 03-20-2009, 11:16 AM
ShantasticZJ
Thanks
Adam
Since there wasn't an old one in the way it was easy to do ours. Another jeeper gave us a free headliner (and all the upper trim.) out of a 95 he was parting out.
It was sag free if you can believe it lol. It didn't have any cardboard backing. It was fabric on stiff foam. We just removed all that upper trim and molding, and gently pulled it out. With all the trim out it started to fall off the roof on its own.
Installation was just the reverse. No glue needed. We put it in place and started putting the trim all back in. Other then a couple water spots, it looks 500x better in there.
-Shann
Originally Posted by gaTJgal View Post
LOOK!!! I escaped the kitchen!!!!
HERS: 98 5.2 ZJ Loredo. 249 to 242 Swap. Skyjacker Hydro shocks, Painted Canyons, Bedliner on the rocker panels. Front tow hooks. 2" Budget Boost. 31" SXT a/t.
. De-striped, roof rack, 31" BFG's. Lifted with 3" rusty's coils, s-10 bastard pack, Rancho shocks up front, and F-150 shocks in back.
Theirs: 85 XJ 2dr 5 speed, v6, junkyard build trail rig/project
1986 F-150 The Purple Beast! 300 I6, tow package, granny stick, 3" body lift and 35" wild country's
ShantasticZJ is offline
post #10 of 21 Old 03-20-2009, 02:46 PM
husker88jeep
1988 XJ Cherokee
I tried that...
Unfortunately there are a pluthera of variations to headliners on Jeeps. Some have short sunvisors w/ remote keyless electronic gadgets on them, some have speakers attached to roof. Some have all kinds of wierd crap on them. I had to reline my old one because I couldn"t find a matching fiberglass panel to replace it with. I followed this routine and it worked excellent....http://www.wlsheadliners.com/tutorials/cherokee/
Only do not use the 3M adhesive, use the stuff from Permatex (orange can) You'll need 2 cans of this stuff..can be purchased at Advance Auto Parts. Also make sure you are somewhere out of the wind.. and make sure you have someone there to help you. This glue is Super fast acting and you only get one shot at it before it sticks. If you try to pry this stuff up. you will tear up the fiberboard. (ask me how i know) good luck and take your time
husker88jeep is offline
post #11 of 21 Old 03-20-2009, 07:31 PM Thread Starter
mhall101
i do have speakers in the rear of the head liner, is that oem?
mhall101 is offline
post #12 of 21 Old 03-20-2009, 07:37 PM
nosaint
cant help with the headliner, but I'm in MJ too!
nosaint is offline
post #13 of 21 Old 03-20-2009, 07:41 PM Thread Starter
mhall101
nosaint, you woundnt have the black lifted jeep do you?
mhall101 is offline
post #14 of 21 Old 03-20-2009, 07:42 PM
nosaint
no, 4 door red sport
nosaint is offline
post #15 of 21 Old 03-20-2009, 08:24 PM
RitterXJ
1990 XJ Cherokee
make sure you do it with this cause its the only way it will work
Just
Everybody
Elses
Parts
My Cherokee's very slow progress in pictures:
RitterXJ is offline
Head Liner VDuBLuv82 XJ Cherokee Technical Forum 2 05-11-2009 12:37 PM
head liner question jamiet XJ Cherokee Technical Forum 2 04-16-2009 01:39 PM
Head liner. homelessduck XJ Cherokee Technical Forum 13 12-13-2006 07:20 AM
camoflauge head liner keystone XJ Cherokee Technical Forum 14 08-21-2006 02:29 AM
Rhino liner / Herculiner (truck bed liner paint)...question VDoubleUVR6 XJ Cherokee Technical Forum 4 08-10-2006 09:23 AM
