I need experts help!! Oil pressure guage at zero always not sending unit!! Help - JeepForum.com
post #1 of 9 Old 05-29-2012, 01:54 PM Thread Starter
steelbluexj
Hi to all, I have a 98 jeep xj 4.0l auto. My issue is that after I start the oil pressure guage never reads!! It will bump a little but not up to the first reading. I have tried the following: 5 different oil pressure sending units including 2 mopar ones, a jumper wire to trick the guage, a new pcm, swapped clusters, bypassed the splice block and ccd bus(which is now hooked backed up to the original way)... Seriously people I need help with this issue, Ive had three different mechanics and a ton of money spent to try and fix this!! I am only in desperate need to fix because I have found an 01 yellow sport for a great deal!! Please anybody with any input would be greatly appreciated
steelbluexj is offline
post #2 of 9 Old 05-29-2012, 03:50 PM
cactus_jack
You could have a weak connection somewhere. Clean all of your grounds thoroughly. Trace the harness wire from your sending unit clear to the computer and check it for cracks, bad grounds, etc. May not be the problem but it cant hurt to try. Good luck and let us know what you find.
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #3 of 9 Old 05-30-2012, 08:15 AM Thread Starter
steelbluexj
I've checked all the wiring, I had a mechanic hook up a computer that sends a pulse through the wire to make sure it's good from one end to the other all the way to the cluster. We are still completely stumped with this issue
post #4 of 9 Old 05-30-2012, 08:17 AM
Saudade
1988 XJ Cherokee
Did you use a mechanical gauge to verify the oil pressure?
Saudade is offline
post #5 of 9 Old 05-30-2012, 09:29 AM Thread Starter
steelbluexj
Yes I installed one from advance and my oil pressure is great! It's about 45-50 at cold start so it's good.
post #6 of 9 Old 05-30-2012, 05:06 PM
GrnJeep
Did you try the key trick to get the guages to run through the test cycle? I cant remember off hand what the key on off count is but maybe someone on here will remember.
GrnJeep is offline
post #7 of 9 Old 05-30-2012, 05:10 PM Thread Starter
steelbluexj
Yes many times I have tried the guage sweep test. They all work and like I said I even swapped clusters. Still no reading from the guage
post #8 of 9 Old 05-30-2012, 07:43 PM
ggjeep
Leave it hooked up and don't sweat it, you've got good pressure.
1996 XJ Sport 4.0/AW4
ggjeep is offline
post #9 of 9 Old 05-30-2012, 07:59 PM Thread Starter
steelbluexj
I have for the time being, but like I said I'm trying to sell it and it will kill any interested parties because 0 oil pressure and check guages light stays on.
help please
Oil Pressure...Guage? Sending Unit? Engine Problem? XtrailratedJ XJ Cherokee Technical Forum 6 03-25-2011 08:23 AM
Temp Guage not working...not the sending unit LandRover XJ Cherokee Technical Forum 8 01-30-2011 09:30 PM
Where is my temperature guage sending unit? ('98 XJ) LandRover XJ Cherokee Technical Forum 11 12-14-2010 03:12 PM
My oil guage is acting up and i don't think it's the sending unit kruucks XJ Cherokee Technical Forum 6 04-29-2009 09:54 AM
oil pressure sending unit, coolant temp unit h2rescue XJ Cherokee Technical Forum 6 01-31-2006 09:23 PM
