-   -   I need experts help!! Oil pressure guage at zero always not sending unit!! Help (http://www.jeepforum.com/forum/f11/i-need-experts-help-oil-pressure-guage-zero-always-not-sending-unit-help-1374701/)
steelbluexj 05-29-2012 01:54 PM
Hi to all, I have a 98 jeep xj 4.0l auto. My issue is that after I start the oil pressure guage never reads!! It will bump a little but not up to the first reading. I have tried the following: 5 different oil pressure sending units including 2 mopar ones, a jumper wire to trick the guage, a new pcm, swapped clusters, bypassed the splice block and ccd bus(which is now hooked backed up to the original way)... Seriously people I need help with this issue, Ive had three different mechanics and a ton of money spent to try and fix this!! I am only in desperate need to fix because I have found an 01 yellow sport for a great deal!! Please anybody with any input would be greatly appreciated
cactus_jack 05-29-2012 03:50 PM
You could have a weak connection somewhere. Clean all of your grounds thoroughly. Trace the harness wire from your sending unit clear to the computer and check it for cracks, bad grounds, etc. May not be the problem but it cant hurt to try. Good luck and let us know what you find.
steelbluexj 05-30-2012 08:15 AM
I've checked all the wiring, I had a mechanic hook up a computer that sends a pulse through the wire to make sure it's good from one end to the other all the way to the cluster. We are still completely stumped with this issue
Saudade 05-30-2012 08:17 AM
Did you use a mechanical gauge to verify the oil pressure?
steelbluexj 05-30-2012 09:29 AM
Yes I installed one from advance and my oil pressure is great! It's about 45-50 at cold start so it's good.
GrnJeep 05-30-2012 05:06 PM
Did you try the key trick to get the guages to run through the test cycle? I cant remember off hand what the key on off count is but maybe someone on here will remember.
steelbluexj 05-30-2012 05:10 PM
Yes many times I have tried the guage sweep test. They all work and like I said I even swapped clusters. Still no reading from the guage
ggjeep 05-30-2012 07:43 PM
Leave it hooked up and don't sweat it, you've got good pressure. :thumbsup:
steelbluexj 05-30-2012 07:59 PM
I have for the time being, but like I said I'm trying to sell it and it will kill any interested parties because 0 oil pressure and check guages light stays on.
The time now is 12:30 PM.
