Quantcast i hear a clunk what could it be? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > i hear a clunk what could it be?
Old 08-04-2009, 10:58 PM   #1
heep of feces
hello folks quick question i am hearing a clunk when i turn on jeep but its not constant and when im driving and i hit a bump in the road i hear it again like there's something lose what could it be jeep drives perfect but noise is bothering me. i have a '96 xj 4.0L auto 4x4 im not sure what else you guys need but any help would be appreciated thx for your time.
100% NDN and STR8 from the REZ
heep of feces is offline   Reply With Quote
Old 08-05-2009, 05:50 AM   #2
cornbrizzle
1992 XJ Cherokee
check axle side track bar bolt for wallowed out hole or worn bushing, check shock mounts and bushings both ends, and all your tie rod ends. Have some one sit inside and start motor and turn steering wheel back and forth while you look at all the steering componets for movement or play, Tighten anything that looks lose It could be many things !!
Brizzle
cornbrizzle is offline   Reply With Quote
Old 08-05-2009, 08:22 AM   #3
99Greenmachine
X2 on the trackbar, also check your swaybar bushings as they are under stress during turns as well.
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 08-05-2009, 10:41 AM   #4
heep of feces
Brizzle
ok i checked this out but eveything looks good.
i was searching threads last night and was wondering if maybe it could be the motor/tranny mounts what do you guys think?
Old 08-05-2009, 11:11 AM   #5
99Greenmachine
Possibly...Motor mounts are more likely especially the Driver side
Old 08-05-2009, 11:34 AM   #6
phattysrt
inspect the t-case shiflt linkage. A common issue is the small bearing that supports the t-case shaft that is supported in between the body and the transmission. I believe there is a TSB on this. Mine was hollowed out and was causing a very noticeable clunking in my floorboards.
ITS A JEEP THING... YOU WOULDN'T UNDERSTAND.
http://www.jeepforum.com/forum/f11/project-cheep-jeep-892777/
1995 XJ 4.0, AW4, 6.5 IRO Long arms, 4.56's, Auburn ECTED Dana 44 rear, SYE, 33's (SOLD)
1998 XJ 4.0 AW4... ALL STOCK... NEW PROJECT
1964 SS Chevelle, BB 396, 700r4. project in the making
phattysrt is offline   Reply With Quote
Old 08-05-2009, 11:37 AM   #7
cornbrizzle
1992 XJ Cherokee
yep, take a flash light and inspect the rubber in the mount they get torn or even sometimes have fallen out !! If they look good check bolts for tightness.
Brizzle
Old 08-05-2009, 01:06 PM   #8
heep of feces
hey thats what it sounds like(clunking in my floorboards) ill check it out when it cools out side thx ill get back to you
Old 08-05-2009, 03:37 PM   #9
conrasm
Check the sway bar bushings and end link bushings as well. It can be frustrating figuring it out. Look at the control arm bushings on both ends. The frame side mounts are close to your feet. Go over all yous supension bolts. I had clunking from loose control arm bolts on the axle (vibration from super swampers), track bar bolt hole ovaled out, bad track bar bushing on axle side, and loose track bar mount on frame.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
Old 08-05-2009, 04:05 PM   #10
1974Renegade
1974 CJ5
My xj had a broken exhaust hanger, and the exhaust pipe was hitting the frame and hitch assembly. It sounded like the whole bottom of Jeep was coming out. I checked all the major stuff, and then finally checked the exhaust, and was dumbfounded when spot welding the hanger back on resolved the issue. So don't be like me and forget the little/simple things.
1974Renegade is offline   Reply With Quote
Old 08-05-2009, 04:08 PM   #11
jeepjunkie408
yeah... mine's the got the same issue... I haven't a clue how to weld... I suppose I should do something about that... the hanger looks pretty well seized on there... goodness. I will have to figure something out.
jeepjunkie408 is offline   Reply With Quote
Old 08-05-2009, 04:30 PM   #12
franknstn_cj5
my 85 has a completely sheared motor mount on the driver side and it doesn't make a peep, so i doubt it's that... but i'd have to X2 on what everyone else said. let us know what happens...
franknstn_cj5 is offline   Reply With Quote
Old 08-05-2009, 09:40 PM   #13
heep of feces
i did check this but all looks good.
Old 08-05-2009, 09:45 PM   #14
heep of feces
ok i checked this out but dont know if its bad i tried wiggling it.. but it seems everything is snug. i noticed this topic on a previous thread(http://jeepforum.com/forum/showthread.php?t=831117) that was up and it sounded like i was having that issue but am not sure... i wish i knew what the hell i was doing.
Old 08-07-2009, 03:41 PM   #15
heep of feces
it was the tranny mount decided to fix that first befor i did the transfer case likage bushing and it fixed the problem happy happy
Glock Forum
