i have a few questions please help - JeepForum.com
post #1 of 2 Old 07-19-2014, 09:03 PM Thread Starter
loudliftedjeep
ok i have some questions.right now i have a rough country 3 inch lift on my xj.2inch in back 3 in front.wanna go bigger but dnt have much money.so plan on buying 2 inch spacers for front.3inch block for back.and get transfer case drop kit.any other things i have to do if im doin 5 inches of lift?like control arm drop.also can i clear 35 inch tires if i trim fenders
loudliftedjeep is offline
post #2 of 2 Old 07-20-2014, 08:04 PM
muttly
I'd stay away from blocks for the rear and go with longer shackles.At 5 inches you will probally need to do a slip yoke eliminator and a new driveshaft.You may also need a adjustable track bar,new shocks ,longer brake lines,longer control armsand an alignment. I'd buy 1 inch lift shackles and trim the fenders to fit the 35's. I know guys that have no lift sitting on 33's so 35's should fit at three inches
3 inch lift,,31 in.Pro Comp Xtreme AT,
muttly is offline
