I drove my Cherokee into some water and the engine stalled? It wont start now??? - JeepForum.com
post #1 of 12 Old 12-29-2010, 07:07 PM Thread Starter
strokera4
Newbie
So I drove me Cherokee into some water with speed and the engine stalled. I had the car winched out of the water and it wont start now? I found a video of a cherokee doing something similar, but this one seems slightly worse... Here it is:
http://video.ultimatestreet.com/vide...stuck-in-water
Does anyone know what happened to my engine? And is it bad???
strokera4 is offline
post #2 of 12 Old 12-29-2010, 07:58 PM
orangeNblue302
You probably hydrolocked it. You should approach those water holes slower to avoid splashing. It may not be locked but there are ways to get water out
orangeNblue302 is offline
post #3 of 12 Old 12-29-2010, 08:22 PM
96jeepxjcbc
check your dis. cap for water. mine did the same thing. and it was the dis. cap was wet.
ROSCO.96 Jeep xj. 2in CBC lift, CBC air intake, CBC rims, and CBC exhaust.
96jeepxjcbc is offline
post #4 of 12 Old 12-29-2010, 08:34 PM
99XJBeast
Pull your spark plugs, dry them off, reinstall. Will probably crank right back up and shoot water all over the place. Did this to my XJ many many times.
99XJBeast is offline
post #5 of 12 Old 12-29-2010, 10:29 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
wow, deja vu thread to the one in the nontechnical section.
***Chris***
chris87xj is online now
post #6 of 12 Old 12-29-2010, 10:35 PM
connor0770
damn!! same for me!
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #7 of 12 Old 12-30-2010, 07:26 AM
98_XJ
From the sound of it the XJ in the video never dies. I think he just got stuck in soft mud. Yours sounds worse. Let us know if the suggestions above works for you.
1998 Jeep XJ Limited 4x4
- Rough Country Series II 3" Lift
- 31-10.50-15 Duratracs on Black Rocks
- JCR Offroad Stage 3 Front Bumper
2010 Chevy Equinox
98_XJ is offline
post #8 of 12 Old 12-30-2010, 08:05 AM
camjeep3
1988 MJ Comanche
i dont think you said that one right. pull the plugs and turn the motor over with them out so if there is any water, it has a place to get out. once thats done change the oil and put your plugs back and your good
2011 Chevy Silverado ext cab z71
1988 JEEP Comanche 4x4 shortbed:
4.0L w/ 5spd
6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s
High School Jeepers #15
camjeep3 is offline
post #9 of 12 Old 12-30-2010, 08:08 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
No kidding, and pretty much the same answers...........
cruiser54 is offline
post #10 of 12 Old 12-30-2010, 03:00 PM
Sanders88
Your engines probably hydro-locked. If so then it'll need a complete rebuild
Sanders88 is offline
post #11 of 12 Old 12-30-2010, 04:26 PM
egodfrey
egodfrey's Avatar
You know the best way to fix this, PREVENT IT,
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #12 of 12 Old 12-30-2010, 04:33 PM
BriansCJ
1994 XJ Cherokee
Buy a ing snorkel
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
cherokee , engine , jeep , water
91 cherokee 4.0 engine swap,,, wont start? dlvsdh XJ Cherokee Technical Forum 8 09-27-2010 05:56 PM
94 Grand Cherokee 5.2L Engine Wont Start! Possible Fuel Problem!?! mnl_soldier XJ Cherokee Technical Forum 4 05-15-2009 02:43 AM
91 4L engine swap into a 88 4L cherokee wont start treeharvester XJ Cherokee Technical Forum 9 04-22-2009 05:53 PM
Jeep stalled and wont start littleblackXj XJ Cherokee Technical Forum 3 02-18-2008 06:25 PM
Jeep stalled and now wont start et326 XJ Cherokee Technical Forum 2 06-14-2004 02:19 PM
