I believe my MJ has been converted from 2WD - JeepForum.com
post #1 of 14 Old 11-04-2013, 05:41 PM Thread Starter
hollywood_35
1990 MJ Comanche
So, I posted a thread awhile back about my strange looking lower control arm mounts. After digging around replacing front end components and hunting down the cause of my misfiring (sigh) I have found some terrible workmanship.
Take a look below, it seems someone has added components from another vehicle to make this front end. The thing that scares me (as both a welder and and engineer) is the weld quality. If the weld quality is any indication of the effort put into this "conversion", I have my hands full. The only explanation I can think of is that this 1990 MJ started it's life as a 2WD and someone has converted it to 4x4 by adding the necessary hardware. Unfortunately, I'm new to the platform and I'm not certain how things should look. So, let me know what you think.
Here you can see the spring spacer, which has been somewhat stitch welded in place, and the shock mount, welded perfectly
Again, the shock mount
Behind the spring spacer, you can see this lovely stud has been welded in place. Upon inspection, it's for the motor mount. Great.
Bear with me on this one, it's the passenger side motor mount. You can see the one bolt coming through the fenderwell (directly to the right of oil filter) with nothing attached to it. So... not sure what to think about that.
Same on the driver's side. Directly center of the EGR, to the left you can see a bolt that was obviously put there, doing nothing.
Again, just showing the welds on the control arm mounts.
This doesn't really bother me, oddly enough it actually makes me feel better. knowing that whatever I'm going to do with this MJ in the future, I'm not cutting up some pristine and rare truck. Being in Canada these trucks are almost non-existent, I'm always getting stopped and asked what kind of truck it is. Pretty cool to be honest.
hollywood_35 is offline
post #2 of 14 Old 11-04-2013, 05:57 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
While the XJ/MJ unibody construction is not pretty, it is functional and strong. A 4wd conversion is 100% bolt on, all the brackets and bolt holes are pre-existing. Your MJ is normal. The open studs and extra holes are for locating/indexing sub-assemblies and sheet metal during assembly. Snotty looking welds are also common.
The stacked coil spring spacers are kinda Bubbafied, but that's an easy fix.
CJ7-Tim is offline
post #3 of 14 Old 11-04-2013, 07:23 PM
ltrail
1984 XJ Cherokee
Ya, I wouldn't use your professional opinion to build the mj. Just assume that engineers of the past had good ideas. otherwise you'll end up like my first xj which is now re-unibodied. I used 2x4 .188 to make a frame front to rear. Tied in sliders/boatside and will be adding a cage and such to support my new drivetrain.
These are pretty well built for a bunch of sheet metal. I beat mine for a long time before I did all this nonsense. If you truly flog it regularly get some frame stiffening. Otherwise run it!
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 14 Old 11-04-2013, 07:49 PM Thread Starter
hollywood_35
1990 MJ Comanche
Oh dang! That kind of worries me in the sense that these welds are production. But also awesome in the fact that they're seriously just built without all the technology of today's vehicles. I think that's one of the reasons I enjoy it so much.
Side note, realized my engine mounts are almost non-existent. I saw someone mentioned some good ones in a thread a few days ago but the name is escaping me. Thoughts?
post #5 of 14 Old 11-04-2013, 08:06 PM
Paradise XJ
1988 MJ Comanche
Brown Dog
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #6 of 14 Old 11-04-2013, 08:17 PM
Motorcharge
x2 on Brown Dogs
If you can put your VIN in here or request a build sheet based off it from Chrysler to find out if it was 2wd. 4wd swaps were pretty common and like others said, they're entirely bolt on, no fabrication is required.
http://www.cherokeeforum.com/vindecoder.php
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #7 of 14 Old 11-05-2013, 11:00 PM Thread Starter
hollywood_35
1990 MJ Comanche
Turns out it was built as a 4wd. Interesting tidbit though, it says the truck came with a 89 litre fuel tank. I have never once put more than 60 into in. And that was reading very empty on the gauge. I imagine the gauge must be off, meaning I've been fueling up at 1/3 of a tank when it's reading bone dry.
post #8 of 14 Old 11-06-2013, 08:13 PM
ltrail
1984 XJ Cherokee
I agree the brown dog mount is popular, but if you are a welder and or engineer I would build some. Easy to make, materials and poly bushings are cheap. And you could give a little engine lift to raise the drive train and achieve the flat belly if you plan on wheeling it some.
ltrail is offline
post #9 of 14 Old 11-07-2013, 02:16 AM
Timo_90xj
Timo_90xj's Avatar
If you look at any XJ, MJ or ZJ, you will notice they all look just as crappy regarding the welds.
It sure is functional, but as a more heavily used wheeling platform on harder trails it is not exactly strong unless frame stiffeners and a cage is added. On mild-to-medium built XJs the unibody does its job fairly well with properly tied-in front & rear bumpers etc., but on the harder stuff these Jeeps start to fall apart within a couple months of wheeling It is not uncommon to find multiple cracks and spot-weld separated.
***Under construction***
Timo_90xj is offline
post #10 of 14 Old 11-07-2013, 12:29 PM
Azzy
Or you could have 20 litres of sludge and dissolved liner in there! Might be worth dropping just to change the filters.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #11 of 14 Old 11-09-2013, 01:06 AM Thread Starter
hollywood_35
1990 MJ Comanche
Unfortunately being in school for engineering at the moment has taken me away from my shop. I have a few hand tools and a non-heated garage with a severely busted up floor; being -30 most of the winter makes that... suck. My welders and all the goods are taking residence in my parent's garage 6 hours away until I'm done this degree. The woes of being a student I guess.
post #12 of 14 Old 11-09-2013, 01:09 AM Thread Starter
hollywood_35
1990 MJ Comanche
I was at 1/8 of a tank and topped it up yesterday. Took 50 liters. That doesn't make a lot of sense. What type of filters do they have? Just a sock-style over the pump?
post #13 of 14 Old 11-09-2013, 04:34 AM
Timo_90xj
Timo_90xj's Avatar
There's a small mesh filter on the intake, and an inline filter outside of the tank on the drivers' side uniframe rail.
post #14 of 14 Old 11-09-2013, 08:36 AM
Motorcharge
The gauges on these aren't all that accurate either. Plus gas gauges tell you you have less than you actually do by design to keep you from running out of gas.
|SOLD|
| June 2015 COTM |
