Hybrid cage build (exo-cage + internal) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Hybrid cage build (exo-cage + internal)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Superchip Flashcal In StockThe Original 3/8" Ruffstuff Diff Cover!
Unread 02-17-2010, 01:07 PM   #1
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
I finally had time to start my cage build, be sure to check here often as I update the page when I get something done.
My cage will be much similar to what Erics' cage is - but it of course has things and ideas of my own. But I've looked at COJeepin's engine exo, Erics' hybrid cage and quite a few other cages on NAXJA and Pirate to figure what kind of cage I want.
I finally got my tubes yesterday, nine sticks of ~1.5" (ID) x 0.120 DOM - these tubes are in millimetre standard so not exact figures. OD is ~1.8". Bought at a very reasonable price of slightly under 6€ per meter, that's about 50-55$ for a 20ft. stick! I also bought 20pcs of weld-on 90* turns (only ~2.50$ each ), mainly to be used on bumpers and stuff like that where very tight 90* turns are needed.
This is the first time I do something like this, which means I've never used a bender before. I bought one last summer, a very high quality tool. Only downside is it's muscle- powered and cannot be used with a bottle jack. That version would've cost more than double compared to the manual version. Looks like this:
I started the build from propably the easiest part, the front hoop. And that's all I've done so far
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog 404 portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear,...
http://www.jeepforum.com/forum/f11/h...ternal-973910/
Timo_90xj is offline   Reply With Quote
Unread 02-17-2010, 01:29 PM   #2
99Greenmachine
Im subscribed...haha lets see it!
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline   Reply With Quote
Unread 02-18-2010, 12:32 PM   #3
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
This is where I do the bending
It's freakishly cold outside - again. Around 0* right now + windchill, and similar wheather expected for the rest of the week
Got some more tubes bended and welded. A- pillars pretty much done, and the windshield crossbar
This is to show how the a-pillar tubes go up. I wanted some protection for the doors and also follow the bodyline the best I could. Dunno how well this works
I wanted to hug the crossbar as close to windshield as possible, but so that I can still remove the wiper arms if necessary - and the windshield. Barely enough room, but sufficient:
I was also going to bend the a-pillar to front hoop tubes, but I managed to somehow mess up with my measurements and the bends were not in the right place ..good thing is, I can use the tubes elsewhere so they are not useless.
Unread 02-18-2010, 12:35 PM   #4
austinaubinoe
I read your sig....good call on the cage! Looks great so far, really beefy, is it your DD?
austinaubinoe is offline   Reply With Quote
Unread 02-18-2010, 12:41 PM   #5
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Nope, not my DD. Well it could be, but it's just too damn noisy without the carpets and no sound absorbent materials
Unread 02-18-2010, 02:44 PM   #6
bmyohn
Youngin'
bmyohn's Avatar
very cool Timo! Im liking it so far! Im planning on something similar this summer, possible with incorporated fender flares as well. Keep it up buddy
2011 Dodge Ram 1500 Big Horn 4x4
5.7L V8 Hemi
"The Tow Rig"
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline   Reply With Quote
Unread 02-18-2010, 07:11 PM   #7
EricsXJ
The Post man
EricsXJ's Avatar
I don't know how you manage to work out in the cold like that! I must be a wimp because I hate cold weather and it makes it really hard to work on the jeep.
Those A-pillar bars were the toughest bends to do on mine. I'm not sure how to do it other than the way you did with your railstucked in that far.
You sure you can get the wipers off?
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is online now   Reply With Quote
Unread 02-18-2010, 09:23 PM   #8
slimpartywagon
1989 XJ Cherokee
I was wpondering.... Is it possible to tie the A Pillars together underneath the Cowl? I think that would look very clean... but I have never seen it done...
slimpartywagon is offline   Reply With Quote
Unread 02-19-2010, 02:02 AM   #9
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
I looked at that idea yesterday. But there isn't much room because of the wiper motor, and also if you want to use the space for intake there's just no way to do that. Also welding the tube to the a-pillars would be more or less impossible because of the limited space.
Well, it isn't too fun but I manage. Lot's of clothes and a cup of coffee every now and then ..but I'd rather do this in summer
A-pillars sure were hard, rest should be just simple bends. I can get the wipers off, I tried
Unread 02-19-2010, 11:20 AM   #10
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
A-pillar to front hoop tubes almost done, needs a bit more welding and a few gussets. Then it's time for front fenders, rocker tubes (door protection), and then the roof section.
This is what you get for NOT having a notcher ..suprisingly that lead to some swearing
Gotta fill that up with weld and hope it's strong enough. Or maybe I'll redo that later on.
Unread 02-19-2010, 11:39 AM   #11
Bertamus
1992 XJ Cherokee
What are you using for tubing?? Looks like fence post
92 XJ, 3.5 RC Lift, Full Packs, JKS Discos, IRO Trac Bar, D30 HP, Ford 8.8 w/ discs, 31x10.50 KM2's on D Windows, JCR Front Bumper and Tie-ins, Custom built Rear Bumper, Warn 10k winch
Bertamus is offline   Reply With Quote
Unread 02-19-2010, 11:53 AM   #12
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Read my first post It's just painted by the factory to protect it from rust.
Unread 02-19-2010, 12:17 PM   #13
Kettles
Kettles's Avatar
You ought to beable to fill that no problem. The cage is looking good so far!
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output Pictures Build Thread
The Rocket Sheep
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline   Reply With Quote
Unread 02-19-2010, 01:10 PM   #14
Bertamus
1992 XJ Cherokee
My bad... that's what I get for skimming....
Unread 02-19-2010, 02:00 PM   #15
betard_foosier
Gonna build one for me next? Looks great!
betard_foosier is offline   Reply With Quote
