hunting for a dana 44 out of an xj - Page 2 - JeepForum.com
post #16 of 26 Old 02-25-2011, 01:43 PM Thread Starter
96classic
is there any way to tell if the axels are 28 or 31 spline other than pulling them and counting?
96classic is offline
post #17 of 26 Old 02-25-2011, 01:47 PM
austin6137
1990 XJ Cherokee
I wouldn't waste my time at harrys, go to ez pull in new ringold. Same selection as harrys, and you pay the price in the sheet. Which are lower, I hate harrys I'd rather go to ezpull or buy it new before harrys.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #18 of 26 Old 02-25-2011, 01:52 PM
austin6137
1990 XJ Cherokee
And fwiw a rear at harrys is 48.20 with a 10.00 core and no drums. A rear at ez is 50.00 complete.
post #19 of 26 Old 02-25-2011, 03:00 PM Thread Starter
96classic
yeah you're right ez pull is a lot closer to home and they will torch it out for an extra couple bucks
post #20 of 26 Old 02-25-2011, 06:29 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
ive heard that 28 splines came from rangers, 31 splines are from the explorers
Jamison
ajamison is offline
post #21 of 26 Old 02-25-2011, 06:38 PM Thread Starter
96classic
thats good to know... im assuming the 31 spline is better???
post #22 of 26 Old 02-25-2011, 06:46 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
yes it is
Jamison
ajamison is offline
post #23 of 26 Old 02-25-2011, 06:55 PM Thread Starter
96classic
awesome thanks for the help
post #24 of 26 Old 02-25-2011, 06:57 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
no problem, good luck on your hunt for an 8.8!
Jamison
ajamison is offline
post #25 of 26 Old 02-26-2011, 07:19 AM
DieselDreamer
http://eastcoastgearsupply.com/i-476...-assembly.html. I found these guys.
They sell an 8.8 that you can build to your specific satisfaction. Honestly hot a bad option for someone on a budget. You could pull one from the yard but then you need parts and adapter kits to get it into your XJ. They have everything you need and a little more. For a few grand you can get a decked out Ford 8.8 where as a fully built Currie 44 or Dynatrac 44 will be significantly more. Maybe your rich or your building a rock crawling nightmare, I really don't know. However if your like me on a budget, and just want something stronger than the Chrysler 8.25 with better gear options, these guys might be worth contacting.
Erik
DieselDreamer is offline
post #26 of 26 Old 02-26-2011, 02:18 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
good link, but holy crap can that get expensive to have them rebuild it...
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
dana44 , xj
XJ Hunting AUSHii XJ/MJ Cherokee Non-Technical Forum 5 02-10-2010 10:59 PM
4.0 ho hunting for revs racingbrett XJ Cherokee Technical Forum 0 12-16-2009 01:41 AM
Winch Hunting AngryDog XJ Cherokee Technical Forum 2 03-28-2009 03:17 PM
Hunting in the Junkyard GreenBro4 XJ Cherokee Technical Forum 2 09-10-2007 03:21 PM
XJ Deer Hunting namtrah XJ Cherokee Technical Forum 3 06-08-2004 01:00 PM
