hunting for a dana 44 out of an xj - JeepForum.com
post #1 of 26 Old 02-25-2011, 09:35 AM Thread Starter
96classic
i wanna do an axle swap in my 96 classic...i know the 44 comes equipted with certain xj's but im not sure what ones they come in. if any one has any info to steer me in the right direction that would be awesome
96classic is offline
post #2 of 26 Old 02-25-2011, 09:41 AM
Ben
Good luck.
1987 is your year.
Ben is offline
post #3 of 26 Old 02-25-2011, 09:44 AM Thread Starter
96classic
any specific kind of cherokee?
post #4 of 26 Old 02-25-2011, 10:39 AM
XGoBoomJ
1997 XJ Cherokee
the one in the search box
I am the Stormtrooper..
XGoBoomJ is offline
post #5 of 26 Old 02-25-2011, 10:41 AM
dukie564
1995 XJ Cherokee
i posted in the other thread, but here you go:
sometimes came in older XJs 1987-1989 with heavy duty tow package, but are very hard to find
Also they can be found in MJs from 87-92. They came in the Metric ton package, as well as some other models. Be advised the MJ one is not a bolt in swap, the perches need to be moved, and shock mounts welded on.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #6 of 26 Old 02-25-2011, 10:49 AM Thread Starter
96classic
thanks dukie
post #7 of 26 Old 02-25-2011, 12:06 PM
bigbike
1995 XJ Cherokee
Look on craigslist and on Forums. Are you near Harrys-u-pull? Try looking there.
bigbike is offline
post #8 of 26 Old 02-25-2011, 12:55 PM Thread Starter
96classic
yes as a matter of fact i am near harry's and i'm going up there sunday to take a look. is it hard to tell the difference between a 35 and a 44?
post #9 of 26 Old 02-25-2011, 01:00 PM
dukie564
1995 XJ Cherokee
Dana 35c (round cover):
Dana 44 (stop-sign like cover)
dukie564 is offline
post #10 of 26 Old 02-25-2011, 01:02 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
an 8.8 might be an easier find for you, and its not hard to do the swap, plus its stronger than the dana 44
Jamison
ajamison is offline
post #11 of 26 Old 02-25-2011, 01:05 PM Thread Starter
96classic
thanks for the pics. i was considering an 8.8 swap, but don't i have to relocate spring perches and shock mounts?
post #12 of 26 Old 02-25-2011, 01:08 PM Thread Starter
96classic
what year explorer would i get the rear out of?
post #13 of 26 Old 02-25-2011, 01:20 PM
dukie564
1995 XJ Cherokee
yes you do have to relocate the shock mounts and spring perches.
A 8.8 out of a 96+ explorer is ideal width wise and has disc brakes
These should help you understand what's involved:
http://www.jeepforum.com/forum/f11/8...ite-up-530202/
http://www.jeepsunlimited.com/forums...d.php?t=371713
dukie564 is offline
post #14 of 26 Old 02-25-2011, 01:38 PM Thread Starter
96classic
sweet those links are very convient. i think im gonna ditch the 44 swap and go with a 8.8...im going to the junk yard this weekend and im pretty sure itll be much eaiser to find a 8.8 vs a dana 44
post #15 of 26 Old 02-25-2011, 01:41 PM
2doorxj
2doorxj's Avatar
If you go to harrys there are literally hundreds of 8.8s, and theyre only like 60 or 70 dollars.
2012 Cherokee of the Year
2doorxj is offline
dana44 , xj
XJ Hunting AUSHii XJ/MJ Cherokee Non-Technical Forum 5 02-10-2010 10:59 PM
4.0 ho hunting for revs racingbrett XJ Cherokee Technical Forum 0 12-16-2009 01:41 AM
Winch Hunting AngryDog XJ Cherokee Technical Forum 2 03-28-2009 03:17 PM
Hunting in the Junkyard GreenBro4 XJ Cherokee Technical Forum 2 09-10-2007 03:21 PM
XJ Deer Hunting namtrah XJ Cherokee Technical Forum 3 06-08-2004 01:00 PM
