Hum/Drone/Vibe above 35 - JeepForum.com
post #1 of 5 Old 01-16-2014, 10:43 AM Thread Starter
squirlgod
Alright so I has some exhaust damage that was causing all kinds of drones and vibes, but I just got that all fixed yesterday and now I still have a slight hum/vibe above about 35. It gets louder the faster I go and It even happens when I'm in neutral and slowing down. I can feel it in the steering wheel and the floor and everything. The main reason for my concern is that its not just a noise....its definitely caused by something vibrating. I have a 3 inch lift and a TC drop and have never had this kind of issue until recently. After researching all I can find is people talking about pinion and driveshaft angles etc but like I said this happens regardless of engine activity and is directly related to speed. Could it just be a wheel out of balance? wheel bearing? any ideas on where to start? thanks
"Yeah....It's Purple."
squirlgod is offline
post #2 of 5 Old 01-16-2014, 11:37 PM
sAe23
1995 XJ Cherokee
Did anything traumatic happen prior to the vibration appearing, or did you make any hardware changes?
Have you tried rotating the tires to see if the symptom changes?
sAe23 is offline
post #3 of 5 Old 01-17-2014, 08:18 AM Thread Starter
squirlgod
Well to be honest the jeep was stolen and driven to California before i got it back...so I'd say that was traumatic haha. Like I said it had exhaust hanger damage which was causing the exhaust to touch the body in some places but I just got it back from a muffler shop and they did a great job it looks like new. I'm thinking I'm going to rotate the tires and see if anything changes. The thieves didnt take any parts off the jeep and I went over everything when I got it back pretty closely. It really just looks like they just used it as transport. I think the exhaust damage might have even happened when it was getting shipped back so it would make sense that whatever is causing this is caused by typical wear. At least thats what I'm leaning towards
post #4 of 5 Old 01-18-2014, 02:11 PM
sAe23
1995 XJ Cherokee
Um, yeah...
Is the steering wheel moving back and forth, or do you just feel vibrations through it?
Do the drive shafts look straight? Any scrapes? Looseness in the U-joints?
sAe23 is offline
post #5 of 5 Old 01-20-2014, 11:12 PM Thread Starter
squirlgod
I'd say I just feel vibrations through it. The driveshafts look alright but I'll double check with a closer eye and give the u joints a good tug to see if theres anything going on there.
