#1 | ||
Cant edit my user title
HP30 w/ 4.10s?
Just got done reading the FAQ and found this surprising. Maybe even something that I could use to my advantage. Did DC ever put 4.10s in an HP30? That would save me quite a bit of trouble and $$...
![]() Quote:
Andy, KD8EIA | USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers | "Don't take life too seriously, You'll never make it out alive." "A government big enough to give you everything you want is a government big enough to take from you everything you have" - Gerald R. Ford in an address to a joint session of Congress on August 12, 1974 |
#2 |
Well, if it was 4wd and the rear had 4.10s, then the front must have had them.
Addco swaybar for sale http://www.jeepforum.com/forum/showthread.php?p=4664677#post4664677 |
#3 | |
Is this guy serious?
#4 |
I don't know why it would be in the FAQ, if they never put them in there...
![]() Trick is...can you find one? All the time and effort spent to find one, it might be worth it to just buy the gears.
99 chilipepper red XJ: Race car tow rig. Turbo project in the works. Head of Core production - www.CortekSystems.com Owner of Boostwerks.com Website in development. |
#5 |
Youre answer is pretty much in your post... D30 HP used from 84-99, and then it states that 4.10s were put in XJs with the 2.5L.
#6 | ||
And if it were to have 4.10s, again... ![]()
#7 |
If you can find one in your area yes, they'll be the less desireable vacuum disconnect axle most likely though.. I saw like 2 in the junkyard this weekend here in Albuquerque NM.
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies... FiveZeroFive XJ 8.25 Rear End Disc Brake Conversion For Sale! |
#8 | |
#9 |
Forum God
2 piece axles. driveshaft will not spin when in 2 wheel drive as opposed to a non disco one which will always be spinning. vacuum can fail thus leaving u without 4x4 i suppose. theyre undesirable as mentioned above. basically its a system which connects and disconnects axle shafts together to provide power
also the older crappier smaller ujoints (260s) of course these can always be converted to one piece shafts
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me; Thy lift and thy tires, they comfort me. Thou preparest a spotter before me in the presence of mine obstacles; |
#10 |
So they're just crappy inner shafts? If that's all then no problem. I'm going chromo anyway.
Basically, they're like lockout hubs, but really really really crappy?
#11 |
check out
http://www.jeeptech.com/axle/d30.html it talks about the wrangler vacuum disconnect. same system used on XJs with it. Also http://www.jeepforum.com/forum/showthread.php?t=39873 scroll down to 4WD Engagement problems
#12 |
Greg, thanks for the links. Makes sense.
So my next question, what years should I look for in the junk yards? What are the differences between the years? Thanks.
#13 | ||
look for a pre 99 cherokee/tj with a 2.5L and 4wd
| 98 Jeep Cherokee | 4.0L Straight Six | AX-15 5-Speed | NP 231 | Dana 30 | Chrysler 8.25-29 Spline | | Old Man Emu 3" Heavy Duty Spring Rate | Alpine CDA-9853 | Uniden 520XL CB | K40 Antenna (56" Whip) | RLF CB Mount | Flowmaster Super 44 | Duals | | AR Ansen Sprint's on 31x10.5" BFG Rugged Trails-Summer | | Stock Wheels on 30x9.5" AT's -Winter | | Exhaust Clip | Cardomain | Dual Outlet Flowmaster Club- Super 44Dark Descendant Dirty Tees Quote:
#14 |
The Post man
But as the specs state, if its an older axle it may have the off chance of being 4.56 so just verify the ratio before you pull it to make sure. I'd look for a newer year (92 - 99) to avoid the vacuum disconnect. Good chance that anything with the 2.5L has 4.10's.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#15 |
4.56's only came in the 2.5L with the AW4. Most of the ones I have seen & heard about were 89's. JIM.
96@6 & 92@3 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
