Hp D30 - JeepForum.com
post #1 of 5 Old 05-22-2003, 03:38 PM Thread Starter
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Hp D30
Decided to beef up the front end too. What year should I look for a HP d30 in? 95-99?
Are they all 27 spline, or can you upgrade to 29 er something?
Gonna get a warn hub conversion & alloy shafts with locker & gears so I guess spline doesn't matter... or does it?
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #2 of 5 Old 05-22-2003, 04:24 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I could be wrong, but doesn't the warn kit come with new axles? I thought I remembered reading they do, but I could be wrong.
They might not give you the option of a higher spline count. On the other hand, I'd assume the replacemnet axles would be stronger than stock.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 5 Old 05-22-2003, 07:54 PM
Deaver
Re: Hp D30
You should look 96-1/2 to 99.
They are non-disco and have 297 UJoints,
Look at Superior Evo series axles (Super 30) from Drivetrain direct. Warn's will add 3/4" track width to each side. Evo's are alloy and allow unit bearing and no additional track width
Warn Hub Conv = ~$750 to 900
Warn inner axles = ~$350
Deaver
Don't talk much but listen like hell
Deaver is offline
post #4 of 5 Old 05-22-2003, 08:07 PM Thread Starter
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Yeah but I want the hub conversion, don't like the non serviceable hubs, plus I'd like to unlock the hubs since I'll be going with a locker... don't really care about track width increase
post #5 of 5 Old 05-23-2003, 06:02 AM
dscrotty
dscrotty's Avatar
If you're getting the warn hub conversion anyway, just find HP30 anything w/o vacuum disconnect. look enough and you might even find a free one, or damn cheap.
come to think of it, all you really need is the housing, gears and knuckles. I've seen a few housings for free on JU and somewhere else (just can't remember where)
92 XJ Laredo 4.0 5SP. 3.5" RE lift, RE adj LCA's, 31x9.5 TSL radials on AR 767's, custom hand throttle, rusty's towhooks, C4x4 rockrails, rear bumper and tire carrier, probably a few other things too.
dscrotty is offline
