How to use 4X4? - JeepForum.com
post #1 of 51 Old 11-12-2008, 11:39 PM Thread Starter
deaf_xj
How to use 4X4?
hello, i am new here and i have a 91 jeep cherokee 4x4.
i want to know how to drive a 4x4???
i know i have 2L, 4H, N 2H but i dont know how to use it, so can any one explain to me or tell me about it please??
deaf_xj is offline
post #2 of 51 Old 11-12-2008, 11:45 PM
Goobersbro
its pretty simple
uhm so yea your 2h is what your in whenver your driving, the 4h is for driving at highway speeds but in 4 wheel drive so lets say its snowing and your driving on the interstate that would be the best time to use it, 4L is 4 wheel drive with low gears so if your off on a trail and meet a tuff obstacle or if your trying to pull a friend out of a mud whole you would use your 4 low and N is Neutral this is my best shot at trying to exlplain it to ya hope it helps
My marshmallow build
Goobersbro is offline
post #3 of 51 Old 11-12-2008, 11:51 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
well by 2L i assume you mean 4L. since you have just one 4H option, that means you have the NP 231 transfer case (the NP 242 also had a full time option in 4H). its a very good transfer case and common in most jeeps. it is shift on the fly which means you can shift in and out of 4H while driving, preferably under 55. but while in 4WD, you cannot drive on streets or paved surfaces since the front and rear driveshafts spin the same speed, causing the transfer case to bind when turning. so only use 4WD on dirt or other low traction situations. to shift in and out of 4L, you should be moving about 2-3 MPH but not any faster and not stopped. 4L gives most traction and torque when needed most like when climbing steep hills, rock crawling etc. N is used when towing
1990JEEPXJ is offline
post #4 of 51 Old 11-13-2008, 12:06 AM
olds442
olds442's Avatar
having 4L,why would that mean its the 231?(if thats what you meant) obviously it is but not because of the 4L, the 242 also has low, but also a part time and full time position. So yes its the 231. You can be stopped when putting it into 4Low just make sure your transmission is in N, if it wont go in the yes let it roll a little bit while trying, should do the trick. But what he said was true, the part time on the 231 should really only be used on low traction surfaces. If you want a TC that you can drive around on the street, you'll want the np242
*another thing is you cant rely on the shift plate, mine came with the 242 plate but with the 231 tc from factory.
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline
post #5 of 51 Old 11-13-2008, 12:17 AM
Goobersbro
uhm
i want to point out the fact while we are at it that he lives in hunnington beach CA so the only time he would ever be using the 4 wheel drive and driving on the road would be like for instance if he was driving to the ski resort and while he was up on the summit it started snowing in this instance you would be fine to drive on the street and use your 4 hi its just when making sharp turns that it will make you skip and jump I live an hour and a half away from tahoe and drive up to the ski resorts all the time and dont have any issues with my 4 high when i m driving on I80 now if you lived in tahoe and you were using it to drive around in town as a DD then you might want to consider changing your TC
post #6 of 51 Old 11-13-2008, 12:27 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
yeah i did word it so it seems like that didnt i, consider it fixed for clarity
post #7 of 51 Old 11-13-2008, 07:33 PM Thread Starter
deaf_xj
ok i got it and thanks guys, also which gear should i used if i driving into a hole of mud?
deaf_xj is offline
post #8 of 51 Old 11-13-2008, 07:42 PM
olds442
olds442's Avatar
mud you say? you want 4LO, get that extra torque to keep the wheels moving and keeps the tires spinning to clear out the mud. Put it to the floor and hold on
Family Wheelin...
VT
olds442 is offline
post #9 of 51 Old 11-13-2008, 09:26 PM
collkid
Is this your first car?
I'd say stay away from Mud, They cause TONS of problems...
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline
post #10 of 51 Old 11-13-2008, 09:39 PM
bikedude189
1993 XJ Cherokee
1) engage
2) romp
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
post #11 of 51 Old 11-14-2008, 01:24 AM
xlr84fun
Ya..... its probly best if you stayed away from mud. i like it and don't just cuz the fact it gets every where and is hard to clean, also it tends to make things go wrong and really fast. just keep in mind if your driving somewhere and you think you might slide off the road cuz its slippery then engage. and dont go over 55 in 4 high and dont go over like 35 in 4 low.
xlr84fun is offline
post #12 of 51 Old 11-14-2008, 01:29 AM
Inavacuum
35? Really? I'm not saying you're wrong, I've just never heard that. I don't think I'd go faster than 15 or 20.
95 ZJ 4.0 PART OUT: Silver Body; Grey Cloth interior
HPD30;RE BB w/ RE Shocks;KOR Rad Support
KOR XMember/TC Skid
Make an offer on anything you're interested in.
Inavacuum is offline
post #13 of 51 Old 11-14-2008, 02:21 AM
krawler510
Fastest I've gone in 4 low has been about 3. That was on the beach because the gearing is crap until I can afford to change them.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #14 of 51 Old 11-14-2008, 02:36 AM
Inavacuum
aha, yea usually if I'm in 4-lo I'm just kinda creeping..idling even. Heavy throttle in 4-lo is dangerous
KOR XMember/TC Skid
post #15 of 51 Old 11-14-2008, 07:23 PM
Goobersbro
yea
Yea i had a "really smart friend" that tried to pull another kid home and he stayed in 4 low. While he was driving the vehicle caught on fire lol he blew something and because of the heat and a liquid phoooosh it was on fire!!!!! still fun to make fun of him for being such an idiot
