How to test rear defroster - JeepForum.com
post #1 of 5 Old 12-27-2012, 05:18 PM Thread Starter
ecsbabydaddy
Ok, '99 xj, rear defroster switch lights up when switched on. Rear glass does not defrost. Where do I check next ?
ecsbabydaddy is offline
post #2 of 5 Old 12-27-2012, 05:26 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
- Fuses.
- Test for 12 volts at the wires that connect to the window glass.
- Inspect the defrost stripes on the window glass for damage.
CJ7-Tim is offline
post #3 of 5 Old 12-27-2012, 06:26 PM
GetLifted
Mine did the same thing. On the back window in each corner at the bottom of the window there are 2 wires (one on each side). On mine, the passenger side wire broke free from the glass. All I had to do was close the door with myself in the back hatch area and re-solder the lead onto the window.
GetLifted is offline
post #4 of 5 Old 12-27-2012, 07:58 PM
ConradThomaier
My rear defrost also doesn't work. I can see the wires in the hatch opening are broken. They need to be repaired. I don't have any play in the wires so I'll need to open up the headliner and the back hatch and replace some wiring.
ConradThomaier is offline
post #5 of 5 Old 12-27-2012, 08:45 PM
OnTheFence
Engine Bay Fuse Box (PDC)
Kick Panel Fusebox
OnTheFence is offline
