Quantcast How to test: fuel pump relay or pump itself? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > How to test: fuel pump relay or pump itself?
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 11-11-2007, 10:53 AM   #1
tombob
My son's '95 Cherokee, 155k, with the 4.0 engine suddenly will not start. A couple weeks ago it failed to start and then a few minutes later started and has started fine until this morning.
I cannot hear the fuel pump running and there is no pressure in the system after a continued engine cranking.
Is there a way to test to see if the fuel pump relay is the culprit? Or will I have to crawl underneath and disconnect the leads to the pump and test to see if any juice is making it to the pump?
I thought there might be a way to pull the relay and test it somehow.
Thanks guys!
tombob is offline   Reply With Quote
Glock Forum
