How tell what gearing i have? - JeepForum.com
post #1 of 6 Old 06-24-2013, 10:22 AM Thread Starter
bangarang
1981 CJ8
I'm going to buy a 8.25 and was just wondering what gear ratio I currently have. I have a 88 2 door limited. Ive read that it came with either 3.55 or 3.73. Besides counting the teeth on the ring could I call the vin into the DMV and find out that way? The metal tab on my pumpkins is long gone from the po. Thanks for any advice.
bangarang is offline
post #2 of 6 Old 06-24-2013, 10:51 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
TheBoogieman is offline
post #3 of 6 Old 06-24-2013, 11:00 AM
jonsnw93
Or you can go to a jeep dealership and get it there, they just need your vin number. I did that for mine
jonsnw93 is offline
post #4 of 6 Old 06-24-2013, 11:09 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Block the front tires, put the transmission in Neutral and jack up the rear.
For open Differentials, jack up one tire, spin wheel 2X, and count pinion/driveshaft rotations.
If locked or Limited Slip, jack up both tires, spin wheels 1X (both wheels will spin together) and count pinion/driveshaft rotations.
About 3 and one half rotations equals 3.55 gears.
CJ7-Tim is offline
post #5 of 6 Old 06-24-2013, 11:55 AM Thread Starter
bangarang
1981 CJ8
Ok, thanks guys
post #6 of 6 Old 06-24-2013, 02:34 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Look at the tag on either of the diffs. Post up the numbers.
FWIW, can't seem to get build sheets on anything older than 89.
And, an 88 Limited with auto trans will have 3.55 gears stock.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
