how to tell if my tierod ends are bad??? - JeepForum.com
post #1 of 7 Old 10-13-2005, 06:29 PM Thread Starter
frankinjeep
Question how to tell if my tierod ends are bad???
i went to get an alignment today and was told that my inner left tierod was bad i was just wondering how to tell if it really is or not, and should i change all four of them at once or only the ones that are bad. it on a 99 xj sport that im getting ready to lift 3" with a bds kit. its got 145k on it so its just getting broke in.
let me know
thanx.
frankinjeep is offline
post #2 of 7 Old 10-13-2005, 07:03 PM
99XJdude
Get underneath the jeep and grab the tie rod and try to move it around. It should pivot tightly. Any excessive play, or movement means its shot. Most of the time it will make a small clank when you move it, which is due to the excessive play between the ball shank and socket poprtion. Other way is to have someone tug on the wheel and you watch and listen underneath to see if its shot.. your choice.
99XJdude is offline
post #3 of 7 Old 10-13-2005, 07:48 PM
tangofox007
With 145k miles, replace all of them. You can be sure that they are worn.
tangofox007 is offline
post #4 of 7 Old 10-13-2005, 08:20 PM
beckXJ
Would a shot tie-rod/ tie-rod end make a clunking noise while turning occasionally?
1998 Cherokee Sport
Dynomax Cat-back and Magnaflow Cat
Pioneer Premier DEH-P880PRS
Image Dynamics 12" IDQ's
2" BB with 30"s and more on the way
beckXJ is offline
post #5 of 7 Old 10-13-2005, 08:31 PM
Bowhunter46563
Bowhunter46563's Avatar
Sure can as well as a bad ujoint or ball joint
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters
Bowhunter46563 is offline
post #6 of 7 Old 10-13-2005, 08:35 PM
beckXJ
I just got my front u-joint done a few months ago. So, I don't think that's it.
1998 Cherokee Sport
beckXJ is offline
post #7 of 7 Old 10-13-2005, 09:19 PM
RyleyF
I was wondering this as well. My tierod is nice and tight, and it's greased up, (sorry that sounded wrong) I can't move it side to side, but I can kick either side of my tire and it'll move about a half of an inch left or right like it's turning. Is this bad?
Ry's 91 XJ 4 Door
232,000 miles, 4.0, 5 speed NP231, Dana 44 rear
Rusty's 3" Full leaf kit
31" meats
RyleyF is offline
TieRod conversion the303hooligan XJ Cherokee Technical Forum 44 06-30-2009 09:19 AM
JKS TIEROD info the303hooligan XJ Cherokee Technical Forum 3 06-04-2009 09:30 PM
junkyard tierod NCwheeler XJ Cherokee Technical Forum 3 09-29-2006 10:52 AM
V8 tierod Muddy Cherokee XJ Cherokee Technical Forum 5 06-07-2006 03:18 PM
tierod bent YJinSD XJ Cherokee Technical Forum 10 01-23-2006 10:40 PM
