How should I make my xj positrac? - JeepForum.com
post #1 of 11 Old 04-11-2013, 10:47 AM Thread Starter
Combsy09
I have a 98 xj with a Dana 35 rear. I took it trail riding and was very disappointed, so I got aussie lockers for it. They didn't last a whole day and went out on the way home from work yesterday. Not sure if they are just not functioning or if they broke. I was looking into putting a ford 9" in my jeep but I don't know what all I would have to do to just put it in or do I just throw it in and bolt it up and go? Please help!
Combsy09 is offline
post #2 of 11 Old 04-11-2013, 11:28 AM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
What are the aussie lockers doing that make you think they aren't working correctly? Did you get front and rear lockers, or just one? Do you know the difference between a posi (LSD - limited slip differential) and a locker?
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #3 of 11 Old 04-11-2013, 12:44 PM Thread Starter
Combsy09
There not working at all. Put it in drive and it won't move. Only way I made it home was in 4hi. I know a little bit about posi and LSD and lockers but not every detail. I want both rear tires spinning when I'm on a trail. I've heard the ford 9 inch is one of the best ways to go but I don't know anythong about them. This is my daily driver but I like to go trail riding occasionally. I put the locker in the rear only
Combsy09 is offline
post #4 of 11 Old 04-11-2013, 12:52 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Did you install the locker yourself or have a shop do it? If you don't see anything obviously broken underneath (mainly the rear driveshaft), I would take it right back to whoever installed the locker and get it fixed. To have a failure next day while driving on the street would make me immediately assume that the install was done wrong.
Word to the wise though - don't go back screaming that they messed up your Jeep. Just show up, explain to them what happened and ask that they do you the courtesy of looking into the issue and making a repair (after explaining to you what went wrong).
- Justin
post #5 of 11 Old 04-11-2013, 01:14 PM Thread Starter
Combsy09
A buddy of mine has a shop and I went over there and had him do it. He has put lockers in before so trusted him to do it. I was watching him put it all together and when it was done I don't think it was right but the measurements and everything were right. Going to take it back to him and he is going to look at it. I didn't know if I should try to fix this problem or just get a better locked rear end all together. I just know I want good offload capability with a pretty low budget
Combsy09 is offline
post #6 of 11 Old 04-11-2013, 07:09 PM
djb383
What made u think it wasn't right? Google diffs and study up a bit. Basically, there's 3 types of diffs: open, limited slip and locking with the latter 2 being traction enhanced diffs. Positrac or positraction is a General Motors name for one of their versions of a limited slip diff. Here's a decent video showing how the different types of diffs perform. Forget that the video says G80, that's just another (one of many) brand names/versions.
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #7 of 11 Old 04-12-2013, 03:27 AM
Charley3
Positrac is the Chevrolet and General Motors brand of limited slip.
The generic name that applies to all brands is limited slip.
IME with an LJ, limited slip can be very hazardous on packed snow and ice.
A selectable locker is much better IMO.
Charley3 is offline
post #8 of 11 Old 04-12-2013, 03:36 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
The problem you noted on the way home seems more related to the transfer case than the lockers. XJ transfer case linkages are known to be finicky particularly when seldom used. Fortunately it's pretty easy to access and verify functionality or persuade by hand.
***Chris***
chris87xj is online now
post #9 of 11 Old 04-12-2013, 02:41 PM
Charley3
I had good luck with ARB lockers in an LJ.
I am not familiar with Aussie lockers.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #10 of 11 Old 04-12-2013, 08:05 PM
djb383
Some drivers are very hazardous on packed snow ice. I'd much rather have the torque of 2 wheels being applied to the ground in either slick or dry conditions vs a one tire fire. If the driver is not willing to adjust driving conditions, there's the hazard.
djb383 is offline
post #11 of 11 Old 04-12-2013, 08:14 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Don't know why it hasn't been said: did you break your Dana 35?
Luck Favours The Prepared
Anticanman is offline
dana 35 , lockers , posi
