How to Restore My Jeeps Paint Color - JeepForum.com
post #1 of 17 Old 04-15-2010, 08:39 PM Thread Starter
gist901
2011 WK
Hello everybody,
I was wondering if anybody has any good ideas on how to restore a cars paint job. My White Jeep paint job is still going strong and it is not faded or peeling. I would describe the condition as being is stained with dirt. Worse in some areas than in others.
I was thinking maybe buffing her might do the trick, but I don't own a buffer and buffing sounds kinda of dangerous (You can really mess up the paint).
So are there any real good SIMPLE ways of helping to restore some of the color and remove some of this dirt of 10 years?
thanks
gist901 is offline
post #2 of 17 Old 04-15-2010, 08:44 PM
Dannn
use a rubbing compound then a good wax.
1998 TJ - 6.0 Vortec LQ4, 35's, Wheelies and Hurt Feelings Galore.
Dannn is offline
post #3 of 17 Old 04-15-2010, 09:19 PM
cornbrizzle
1992 XJ Cherokee
clay bar
http://www.mothersclaybar.com/
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #4 of 17 Old 04-15-2010, 09:23 PM
baldeagle1
agree with using clay bar. My jeep is also white and I used a kit which includes 2 clay bars. worked awsome
baldeagle1 is offline
post #5 of 17 Old 04-15-2010, 09:25 PM
Mark4883
Rubbing compound will make your paint look brand new man, its awesome.
Mark4883 is offline
post #6 of 17 Old 04-15-2010, 09:41 PM
Carl48
Good old rubbing compound is fine but apply it by hand as a buffer could easily burn thru the paint on an edge or if you bear down too long or too hard. Your paint may look OK but 10 years out there having fun in the warm California sun has taken its toll...go easy. A clay bar would be less aggressive. Some guys use a liquid detailer with the clay bar. Mothers sells a kit with the bar, spray detailer, and carnauba wax. Also check out what Surf City Garage has to offer.
Carl48 is offline
post #7 of 17 Old 04-15-2010, 09:42 PM
Mark4883
Agreed, don't use a power buffer.
Mark4883 is offline
post #8 of 17 Old 04-15-2010, 09:45 PM Thread Starter
gist901
2011 WK
thanks for all of your response, guess I am going to be very busy on Saturday (also installing new Headlights, wiring harness).
FYI - this jeep has spent most of its life in NY, CT, and CO. Just moved out CA - I miss the snow
gist901 is offline
post #9 of 17 Old 04-15-2010, 09:47 PM
Mark4883
Originally Posted by gist901 View Post
I miss the snow
Your paint and underbody sure won't lol.
Mark4883 is offline
post #10 of 17 Old 04-15-2010, 09:52 PM
Jeepaddict
1995 XJ Cherokee
X2. I dunno but lately, I've seen a lot of cars drive by with, "sine wave", shaped burn lines left down the sides from buffers. They looked bad.
Jeepaddict is offline
post #11 of 17 Old 04-15-2010, 10:50 PM
jimbosz07
Do everything by hand, no power buffers. I would do clay bar first. If that doesn't get it out, you could do rubbing compund but remember if you do use that, then you have to use a fine cut cleaner and a polishing wax after to restore the smooth finish.
I've been detailing cars for a few years now. Believe me when I say the clay bar is your friend
1996 Sport. 4.0, AW-4, D30/8.25, 4.56s, rear Tracloc, 4" RE/Bastard Pack, BFG 33x12.5 MTs on black D-Windows, homemade SYE, V8 ZJ tie rod, fancy stereo, custom front bumper in the works, etc.
Originally Posted by _Trucker_ View Post
RE sticker = 8% extra flex, RC sticker = 6.2% extra flex, T&T sticker = 10% extra flex ,ect,ect.
jimbosz07 is offline
post #12 of 17 Old 04-16-2010, 12:08 AM Thread Starter
gist901
2011 WK
after using the rubbing compound / clay ... do I have to rinse the car off before applying the wax?
gist901 is offline
post #13 of 17 Old 04-16-2010, 12:13 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Yes, use a good polishing compound (for safety's sake, make sure it's "Clearcoat Safe." I find that paste compounds work better,) and yes, go by hand (lots of rags, and you'll be awfully damned tired when you're done. Ever see "Karate Kid?" About like that.)
Use the clay bar on any spot that's discoloured enough that the polishing compound won't do anything.
And, yes, I said "Polishing Compound" on purpose. It's a much finer grit than a "Rubbing Compound," and therefore less likely to chew through the clearcoat or colour coat on your paint job (hey, I've seen it happen! Worked in a body shop for a while...)
After the compound and clay do their job, I like to take a handful of clean rags to rinse and very gently wipe the paint surface, to make sure to get any remaining grit/clay off.
Then, apply one (or several!) coats of a quality Carnauba paste wax. I like Mother's or Meguiar's.
No, I don't do this on my Jeep. But, it has helped my wife's Suzuki Verona...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #14 of 17 Old 04-16-2010, 01:56 PM Thread Starter
gist901
2011 WK
Thanks 5-90, sounds like you know what you are doing.
I will give it a try in the next coming weeks
gist901 is offline
post #15 of 17 Old 04-16-2010, 03:37 PM
the6nightmares
I agree with the clay-bar, I bought the Meguiars kit with the 2 bars, spray wax/cleaner, and cloth. I have always taken good care of my Jeep and it generally has a healthy coat of wax on it. Last summer I noticed some places that would feel rough again shortly after the waxing and so I tried the clay-bar. It worked great, smoothed out a lot of areas that I did not think would clean up too well. Certain areas, scratches and whatnot I have used a mild compound on with superior results. Top it off with a nice coat of wax and the 9 year old paint looks like new!
Baltimore County Jeep Club
"A squid eating dough in a polyethylene bag is fast and bulbous. Got me?"
the6nightmares is offline
What color should I paint the wheels/what brand of paint? DreamsOfMoab XJ Cherokee Technical Forum 4 03-16-2010 09:55 PM
What color should I paint the ol 93? lathan888 XJ/MJ Cherokee Non-Technical Forum 14 12-10-2009 10:36 AM
pre97 sport removal of red stripe/black paint restore buubba429x XJ Cherokee Technical Forum 0 10-13-2009 12:00 AM
What color should i paint her? webdog XJ/MJ Cherokee Non-Technical Forum 46 01-10-2009 11:51 AM
How can I restore color to trim? bigred54 XJ Cherokee Technical Forum 30 11-15-2008 10:30 AM
