How to replace your idler pulley bearings. - JeepForum.com
post #1 of 15 Old 12-12-2004, 06:54 PM Thread Starter
Ishodu
I did this on my 87 Comanche. Not sure if all jeeps would use the same bearings or not. I should have took pics when I did the job. But I hope this helps.
Procedure as requested.
What your going to need:
2 6203-2RS/C3 bearings
Access to a press
Piece of round rod 3/4" or so will work fine
A piece of pipe about 3-4" long and with an opening large enough that the bearings will fit inside.
Remove the pulleys first then on the press place the pipe on the bed. Place the pulley on the pipe so that its lined up so the bearing will fall in the pipe when pushed. Then put the rod in the middle of the bearing and push it will the press it will fall through.
To install take the new bearing and place it slightly in the hole. Take the old bearing and place it on top (centered). Now use the rod to push against the old bearing to push the new one in. Stop pressing it in when the bearing is in position. And your done.
Now I know another method that will work well an alternative to using a press.
You need:
Piece of pipe slightly larger than the bearings.
Hammer
Oven and a freezer.
Thick gloves
Remove the pulleys. Place the pipe on a sturdy surface and the pulley on top so that the bearings will fall inside the pipe. Pound them out with a hammer. Now take the bearings and place them in the freezer for about 1 hour. And at this time put the pulleys in the oven. (metal ones only) Heat the pulleys to about 250F. Now all you have to do is slip the new cold bearings in the hot pulleys use the gloves of course. You will have to be fast they will lock together quite fast. And your done.
Never hammer new bearings this will ruin them.
Also common sense is to check to make sure you have the right bearings by comparing them or looking at the #s.
You can also use bearing # 6203-2Z/C3 the difference is the seals. The 2RS are rubber seals. The 2Z is steel Shields. Both will work but the rubber seals are better.
87 Jeep Comanche MT
95 Taurus SHO MTX
Ishodu is offline
post #2 of 15 Old 12-12-2004, 09:51 PM
halfmt1
thanks for the info. might come in handy later.
halfmt1
halfmt1 is offline
post #3 of 15 Old 12-13-2004, 10:01 AM
jandj
jandj's Avatar
you could have just replaced the hole thing. Not sure how much mine cost put it was not very much.
sold my 96' XJ
Look'n to purchase now
jandj is offline
post #4 of 15 Old 12-13-2004, 10:53 AM
ctavel
ctavel's Avatar
A new idler pulley costs les than 20 bucks, so unless the bearing replacement was super cheap I suggest you just buy a new one....
Just my opinion
ctavel is offline
post #5 of 15 Old 12-13-2004, 10:59 AM
LJ_Cool
2003 WJ
you may be right about the cost.
But I think the point is that you can fix it your self, and here's how,
Likewise, one can fix the rusty dakota gas cap problem by disassembling and cleaning and painting the internal spring, rather than just buying a new gas cap.
have fun with your jeep
03 WJ Limited, 04 Overland
LJ_Cool is offline
post #6 of 15 Old 12-13-2004, 12:19 PM
homerscj7
homerscj7's Avatar
idler pulleys can be hard to find sometimes, AutoZone, Advance and Pep Boyz do not carry them and it may take your Napa store a day or two to get it. I wish I could have just rebuilt mine when it went rather then searching for 2 days to find someone local that had one in stock.
The road to destruction is paved with good intentions
homerscj7 is offline
post #7 of 15 Old 12-13-2004, 02:14 PM Thread Starter
Ishodu
Just my opinion
Both bearings cost me about 6 dollars. For 2 pulleys!
87 Jeep Comanche MT
95 Taurus SHO MTX
Ishodu is offline
post #8 of 15 Old 12-13-2004, 02:53 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Thanks for the write up, I appreciate it. I would love to do my own when mine go out just to say I did it. That and the bearings only being $6 doesn't hurt either. I will post a link to this thread in the Tech/FAQ.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #9 of 15 Old 12-13-2004, 03:12 PM
jandj
jandj's Avatar
to save $14 I'll probably just replace the bearings next time. Especially if I had to wait longer than 30 minutes for the pulley. THanks for the info...
sold my 96' XJ
jandj is offline
post #10 of 15 Old 09-06-2010, 11:26 AM
102joe
It seams that these bearings go bad allot does anyone know of a upgrade ? a heaver bearing ?
102joe is offline
post #11 of 15 Old 09-06-2010, 12:49 PM
AZ Jeff
2014 JK Wrangler
They go bad a lot because the NEWEST XJ is 9 years old. It's not surprising that a 9 year old vehicle would need an idler pulley replaced.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #12 of 15 Old 09-06-2010, 10:33 PM
102joe
well Jeff it is surprising that the aftermarket ones I replaced a year ago already went bad. The factory bearings ran about 13 years & 100,000 + miles. I think the problem is with the China or Taiwan bearings the after market manufactures use. So I am wondering if there is a alternative to going with the over priced OEM ones from Chrysler. Thanks for your input tho
102joe is offline
post #13 of 15 Old 09-06-2010, 10:38 PM
tangofox007
Use a good quality bearing, like SKF, F A G, (the automatic censor doesn't like this bearing manufacturer's name) or Timken.
tangofox007 is offline
post #14 of 15 Old 09-06-2010, 10:43 PM
tangofox007
Are you sure that C3 clearance bearings are necessary for an idler pulley?
They don't.
post #15 of 15 Old 05-28-2015, 10:55 PM
jeff1234
ez bearings 2 of them to my door for 16.35 total 1639 rothsvill road lititz pa 17543 item 66203-2rs skf FYI If you remove pullyes pry seal out re back bearings when you replace serp belt you will get 177,000 miles out of them like I did matter of fact the bearings are still good the seals just got hard and crackes a little i'd just bought the seals if i could locate them...i'll look on line some day i'll find just the seals and have on shelf 2 good spare parts..fyi some swimming pool pumps use same berring also. ..so just did a valve job on my wifes 97 rwangler.. oh runs perfwecr had weak intake valve No 1 cyl code 301..county maching brian in san jacinto can't beat him perfect guy perfect valve job labor for me to remove head was simple..one thing i'd like is more info on valve adjustment can they be adjusted while running? lots of mixed info I' torqued nuts to 21ftlbs? but is their a sure better way as to allow for wear of cam and lifters ect?
`2.5 moroe cast head.
` it has been off road 1 time in 15 yrs because i never get to drive it.. sorry no spell check and i'm all thumbs
jeff1234 is offline
'90 4.0 Idler Pulley Squeal jimmyt01 MJ Comanche Technical Forum 3 08-13-2009 03:17 PM
How do i replace Idler pulley? TwistedcaB- XJ Cherokee Technical Forum 12 03-10-2009 05:44 AM
non-A/C idler pulley? nrpalmer32 XJ Cherokee Technical Forum 9 09-13-2008 05:06 PM
93 eats idler pulley Matt Gertsch XJ Cherokee Technical Forum 3 03-24-2008 09:04 AM
New idler pulley bearings. Ishodu XJ Cherokee Technical Forum 3 12-10-2004 06:12 PM
