How to replace flywheel 92 Cherokee Laredo - JeepForum.com
post #1 of 11 Old 06-13-2011, 01:58 PM Thread Starter
jeepgirl92
1992 XJ Cherokee
Sorry for the new thread. I've been searching the site for a little over 2 hours and didn't find exactly the answer I need.
My 92 Cherokee Laredo 4.0 automatic transmission 4wd has been making a really bad knocking sound. It started making noise only when the air was on and over 2-3 days started getting worse, and now does it all the time. I didn't find any cracks in the flexplate, and then replaced the rod bearings. It didn't fix the problem. Any ideas?
I'm considering replacing the flywheel because I can't isolate the problem, but the noise is definitely coming from that general area. What I want to know is if it's possible to replace the flywheel without dropping the transmission? How hard it will be, and how long it should take? I'm hoping I can just slide the transmission back without dropping it? But I'd really appreciate some step-by-step guideline on the easiest way to do it... or suggestions of other things the problem could be before replacing the flywheel.
Thanks in advance!
jeepgirl92 is offline
post #2 of 11 Old 06-13-2011, 03:02 PM
lowicz96
1995 XJ Cherokee
Well i dont have much advice with the noise but i can help to remove the flexplate/flywheel (kinda the same thing but different between manuals and auto's).
1) pull spark plugs
2) rotate motor (with a wrench or similar) until you find one of the torque converter bolts. Loosen all 4 torque converter bolts.
3) Unbolt the exhaust at the header and remove the cross member. Support the trans with a jack. (This is a good time to replace the exhaust donut gasket)
4) lower the rear of the trans down and unbolt the top two trans bolts holding it to the engine. (E12 reverse torx bolts). Then raise the trans back up, support the engine and remove the rest of the bolts holding the trans to the engine.
5) remove the trans with the torque converter still attached to the trans. I usually just use a jack with some wood.
6) then you can remove the flexplate to inspect/replace it.
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #3 of 11 Old 06-14-2011, 07:19 PM
Redrum8675
1978 CJ5
flywheel and flexplate are the same thing on an automatic
CJ 4x4
Redrum8675 is offline
post #4 of 11 Old 07-06-2011, 03:56 PM
brigbeach
How would I rotate the motor with a wrench?
brigbeach is offline
post #5 of 11 Old 07-06-2011, 05:23 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have you checked the tightness of the torque converter to flexplate bolts yet? That's VERY common.
cruiser54 is offline
post #6 of 11 Old 07-19-2011, 11:49 AM
XmuthJ
I'm about to go digging around my 92 to figure out what's wrong, I'll take pics along the way and make a lil writeup cause i can't seem to find anything too detailed about this issue.
|___NEW JEEP___| 87 MJ Lwb | 4.0L | ba10 | D30/D35 | NP231 |______________|
^*^*^ Waiting to go in: 94 YJ AX-15, 99 XJ NP231 (23 spline) ^*^*^
Originally Posted by FrumpD63
Had I bought that lil mazda I was looking at, they wouldnt have found my body until the spring.
XmuthJ is offline
post #7 of 11 Old 07-19-2011, 02:31 PM
Luke94XJ
1994 XJ Cherokee
X2 on the Torque converter bolts, they've been loose on two of my friend's Xjs, use some loctite on them.
Luke94XJ is offline
post #8 of 11 Old 07-19-2011, 02:41 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Remove the lowermost 1/4 moon looking cover where the engine meets the trans and shine a light up there.
Four 15mm headed bolts. See if the one you can see is loose. If it is, remove it, apply Loctite to the thread and tightn it back up. Rotate the engine around til you've done all 4 bolts. A 3/4" socket on the front pulley will turn the engine over.
post #9 of 11 Old 07-19-2011, 09:11 PM
Goldenknob
2007 WK
Blue locktite not red. right? lol
I thought my torque converter bolts were loose and come to find out, it was my cat rattling, lol. Does the sound change with the rpm's of your engine? mine mostly rattled at idle.
Goldenknob is offline
post #10 of 11 Old 07-19-2011, 09:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Color doesn't seem to define the different types of LocTite anymore like it used to. Medium Strength is what to use.
post #11 of 11 Old 07-19-2011, 09:23 PM
brigbeach
thank you
Replace Headliner 97 Jeep Grand Cherokee Laredo Jesy420 XJ/MJ Cherokee Non-Technical Forum 2 05-03-2011 10:49 AM
89 cherokee laredo. Barbdaman XJ Cherokee Technical Forum 3 07-12-2010 10:37 AM
Looking at a 89 Cherokee Laredo sparkchaser XJ Cherokee Technical Forum 14 01-04-2008 08:39 AM
'87 cherokee laredo pcv cobra XJ Cherokee Technical Forum 9 11-10-2006 11:40 AM
cherokee laredo???? kenfyoozed XJ Cherokee Technical Forum 1 06-27-2002 08:48 PM
