how to replace camshaft position sensor? - JeepForum.com
post #1 of 10 Old 02-12-2008, 09:39 PM Thread Starter
f.rock
newbie here. please give details. 1989 cherokee. 4.0
could this be my hard to start problem/backfire problem?
f.rock is offline
post #2 of 10 Old 02-13-2008, 01:32 PM Thread Starter
f.rock
c'mon guys help a brotha out.
f.rock is offline
post #3 of 10 Old 02-13-2008, 01:47 PM
twinsdaddy24
Could be the issue, but more commonly the crank position sensor fails. The cam sensor is a hall effect sensor located under the distributor rotor. It just pulls off. The crank sensor is bolted to the backside of the engine on the drivers side through a hole in the bellhousing. I believe they are 11mm bolt heads.
twinsdaddy24 is offline
post #4 of 10 Old 02-13-2008, 01:48 PM
twinsdaddy24
post #5 of 10 Old 02-13-2008, 02:50 PM Thread Starter
f.rock
crank sensor causing backfire?
f.rock is offline
post #6 of 10 Old 02-13-2008, 05:51 PM Thread Starter
f.rock
anybody????
i went to auto zone and they said my truck doesnt have a camshaft position sensor.
i am wondering if the magnet has fallen off of mine, and where it would be in the distributer, and will i have to pull the distributer to find it.
i purchased a crankshaft position sensor, but i doubt if this is my problem, but mine had burnt wires from the manifold. i repaired the wires, but was still backfiring, so i'll install new one tomorrow.
f.rock is offline
post #7 of 10 Old 02-13-2008, 05:57 PM
KamekLocked
KamekLocked's Avatar
I had better luck finding a camshaft position sensor when calling what it is a Hall effect sensor, otherwise I was also told it didn't have a cam sensor even though I was holding in my hand...
If it is backfiring into the intake then either your ignition timing or cam timing iss off, which the crank or cam sensor could cause that problem.
1999 Jeep Cherokee SE l 4.0 HO l AW4 l NP231
Dana 30/Chrysler 8.25 l 31x10.5x15 Wrangler MT/R
Flowmaster Delta 40 w/stock pipes
Optima Yellow Top l Custom Headlight Harness
Alpine CDA-9886
KamekLocked is offline
post #8 of 10 Old 02-13-2008, 06:05 PM Thread Starter
f.rock
thank you. know anything about the magnet? must i pull the dist?
f.rock is offline
post #9 of 10 Old 02-13-2008, 06:39 PM
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
Take off the distributor cap with the two screws. Take off the rotor. The Cam Sensor is what is left. A black flat thing. Pull strait up on it and it will come out. If the magnet fell off it would be in the bottom of the distributor. it's on the bottom and has no place it could go. Try calling it a pickup, or pickup coil to the geeks at Autozone.
I bring NOTHING to the table.
firefighter1c57 is offline
post #10 of 10 Old 02-13-2008, 06:46 PM Thread Starter
f.rock
thank you Cruzmyxj
f.rock is offline
Where's the camshaft position sensor and how to replace it? broncofire75 XJ Cherokee Technical Forum 28 12-08-2014 01:28 PM
Camshaft position sensor ajeepthing XJ Cherokee Technical Forum 0 09-29-2009 06:16 PM
CAMshaft position sensor BlkBird XJ Cherokee Technical Forum 4 07-21-2007 09:37 AM
halls effect sensor or camshaft position sensor? mackg@goodweb.o XJ Cherokee Technical Forum 4 07-13-2007 06:23 AM
camshaft position sensor???? ThaKingXJ XJ Cherokee Technical Forum 4 03-10-2007 03:21 PM
