How to remove window crank handle? - JeepForum.com
post #1 of 6 Old 03-07-2008, 09:54 AM Thread Starter
RobJJ
Have a '94 Cherokee and must remove a window crank handle...but can't figure out how...nor can I find my manual...please help.
Thanks
RobJJ is offline
post #2 of 6 Old 03-07-2008, 10:46 AM
SteveTheFolkie
I'm assuming that yours isn't held on by a screw - that being the case there's probably a small "U" shaped metal spring/clip thing that engages a slot where the crank goes over the splined shaft. Gently push back the door card behind the crank and see if you can locate it.
To remove it, a blunted screwdriver has been known to work (be careful not to damage the doorcard) - to put it back on the easiest way is to put it into the groove on the crank and THEN shove the whole shebang over the splined shaft.
Just
Empty
Every
Pocket
SteveTheFolkie is offline
post #3 of 6 Old 03-07-2008, 10:58 AM
sk8142
sk8142's Avatar
1994 XJ Cherokee
just pull on it... they pop on and off.
White Jeep curse member #2
1994 XJ 4.0L HO 87k miles
RE 2" BB
30x9.5 Cooper STT tires
AR 767 15x7 wheels
sk8142 is offline
post #4 of 6 Old 03-07-2008, 11:34 AM
jmh30
1995 XJ Cherokee
Your handle probably just pops on and off. Push the door panel in right by the handle. You should be able to see some tabs at the end of the handle. Take a screw driver and pry up on one of the tabs while pulling on the handle. It should pop right off.
jmh30 is offline
post #5 of 6 Old 03-07-2008, 11:50 AM
mall_crawler
All else fails, A BFH will work
[ ] lllllllllll [ ]
The Trail Never Ends.....
mall_crawler is offline
post #6 of 6 Old 03-07-2008, 12:03 PM
lectrode
lectrode's Avatar
1987 XJ Cherokee
Take a rag and put between handle & door panel.
Then work it like you were polishing boots,back and forth motion.
The clip will come off,just watch were it goes
lectrode is offline
remove shifter handle? USA_PRIDE XJ Cherokee Technical Forum 9 04-05-2007 07:57 PM
Window handle removal skid2964 XJ Cherokee Technical Forum 5 02-26-2006 02:36 PM
How to remove window regulator (manual window) kairo XJ Cherokee Technical Forum 6 06-20-2005 08:04 PM
blinker handle @ crank bearings?? inkslinger XJ Cherokee Technical Forum 1 11-27-2004 03:26 AM
window handle removal? mightyone XJ Cherokee Technical Forum 5 07-16-2003 12:05 AM
