How to remove shifter for an automatic? - JeepForum.com
post #1 of 10 Old 05-08-2005, 01:00 PM Thread Starter
fortcollinsram
fortcollinsram's Avatar
I have a 1996 XJ with an auto and I need to pull the shifter out. I don't se any bolt or screws holding it on. How can I pull the shifter out so I can remove the console?
Chris
fortcollinsram is offline
post #2 of 10 Old 05-08-2005, 01:03 PM
devile
devile's Avatar
if u mean just the hand on the shifter, just put the shifter into 1-2 and pull hard...
98' XJ Sport 4.0, Unknown Lift, Bushwackers, 33X12.5R15, AW4, NP231
devile is offline
post #3 of 10 Old 05-08-2005, 01:12 PM
NYCXJ90
NYCXJ90's Avatar
2014 JK Wrangler
have someone watching you when you pull, there is a spring and some other stuff in there that will fly out!
couldnt tell you what to look for because whatever came out is gone for good
'90 XJ Laredo RE 3.5" Super Ride
'95 ZJ 5.9 Stock
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline
post #4 of 10 Old 05-08-2005, 01:19 PM Thread Starter
fortcollinsram
thats it? no screws or anything that hold the handle on the shifter? What does the spring so that shoots out? is it for the button? To put it back on do I just smack it on?
Chris
post #5 of 10 Old 05-08-2005, 01:21 PM
Steve88XJ
Steve88XJ's Avatar
I've had no spring pop out, and my button still works.
I want to say it easier if you hold the button in, and pull like a rat bastid and it will come right off.
Pops right back on too.
Steve88XJ is offline
post #6 of 10 Old 05-08-2005, 01:41 PM
NYCXJ90
NYCXJ90's Avatar
2014 JK Wrangler
it will work fine without the spring in it, it took me a while to find it when it popped, so naturally i questioned whether it was necessary.
it aides in popping the button back out, but there is another plastic piece in there(part of the handle) that keeps tension on there for you.
reinstallation is the same, just pound it on and twist till its straight
'95 ZJ 5.9 Stock
NYCXJ90 is offline
post #7 of 10 Old 05-08-2005, 03:54 PM
devile
devile's Avatar
i can't twist mine it has little things on it so it only sits striaght... and I've never seen a spring!
devile is offline
post #8 of 10 Old 05-08-2005, 04:51 PM
opticalwaveguy
opticalwaveguy's Avatar
Better yet, have someone get it on video, then you can post yourself flailing about after that thing comes loose...
Just be careful!
OpticalWaveGuy
- an online resource for Jeep information
Proud To Be A FF/EMT/Police/Military Club Member #2
opticalwaveguy is offline
post #9 of 10 Old 05-08-2005, 04:53 PM
wolfepack215
wolfepack215's Avatar
1987 XJ Cherokee
Yeah, but don't pull towards yourself.... = fat lip
wolfepack215 is offline
post #10 of 10 Old 05-08-2005, 05:47 PM
Moose_God
Moose_God's Avatar
1994 XJ Cherokee
Lol I had that happen last time I removed my console Be sure to unhook all the lights and crap that go to your shift indicator and 4wd selector bezel thingy. (That's the technical name for it.)
94 Cherokee Sport 4wd (converted from 2wd), AW4, NP231 w/SYE, 6" bastard lift, RC drop brackets, IRO trackbar, 33x12.5 Goodyear MTRs, HDoffroad subframe connectors, prerunner front bumper, homebrew rear bumper, flowmaster 40, 96 booster swap., upgraded headlight harness, 4.56 gears (finally!!!)
Moose_God is offline
how do u remove your auto shifter? jordan_fehlman XJ Cherokee Technical Forum 6 12-21-2008 04:42 AM
remove shifter handle? USA_PRIDE XJ Cherokee Technical Forum 9 04-05-2007 08:57 PM
Automatic Trans Shifter Knob JeepisRandy XJ Cherokee Technical Forum 3 04-01-2007 05:48 PM
automatic shifter problems suckcreek 4x4 XJ Cherokee Technical Forum 3 08-19-2006 06:36 PM
B&M Automatic Shifter Ckwake135 XJ Cherokee Technical Forum 0 07-15-2002 02:47 PM
