How to remove the fuel line connecting to fuel rail - JeepForum.com
post #1 of 4 Old 04-25-2010, 10:09 AM Thread Starter
antibiotics
I am in the process of replaing the fuel injector on my 99 XJ 4.0. I already moved the clip securing the fule line to fuel rail. But How to disconnect fuel hose from the fuel rail. It seems pretty tight and I don't want to break anything.
Thanks.
antibiotics is offline
post #2 of 4 Old 04-25-2010, 11:27 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Buy a fuel line and transmission line disconnect tool set from the parts store. Or, I had better luck with cutting a 1" wide strip of coffee can, rolling it into a circle and using that instead. The 1997-2001 fuel line is held on by 3 or 4 "claws" that need to be gently squeezed, by pressing inward, with the disconnect tool.
CJ7-Tim is offline
post #3 of 4 Old 05-30-2012, 09:01 AM
thirdslide
1991 XJ Cherokee
x2 on the coffee can trick...
I used a piece of roofing flashing. Worked perfectly.
thirdslide is offline
post #4 of 4 Old 11-21-2012, 11:10 AM
delkancott
Any other tips on this? I cut some coffee can to fit in there and pulled into it with the disconnect tool but I can't get the damn thing to budge. :-\
delkancott is offline
no pressure in fuel rail. fuel pump went? sega2010 XJ Cherokee Technical Forum 2 02-06-2010 06:08 PM
No fuel pressure at rail. What else besides the fuel pump could it be? Element96x XJ Cherokee Technical Forum 14 03-28-2009 08:35 PM
fuel injector/fuel rail question LeeBee XJ Cherokee Technical Forum 4 11-16-2007 12:02 PM
fuel rail hard to remove? ChipsXJ XJ Cherokee Technical Forum 2 03-30-2006 08:34 PM
Fuel Line/Connection to Fuel Rail jedwards XJ Cherokee Technical Forum 2 11-04-2004 02:13 PM
