how to remove the front bumper on my 90 jeep cherokee??? - JeepForum.com
post #1 of 12 Old 09-29-2003, 02:07 AM Thread Starter
FREAKY_BEHAVIOR
i need to remove my front bumper,and iw as wandering how many bolts do i take out,and where are they located!!!
thanx!!!
charles
FREAKY_BEHAVIOR is offline
post #2 of 12 Old 09-29-2003, 06:08 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
6 bolts that connect to the frame, 3 on each side. Once you get under there, you'll see them right there. Very simple.
Matt
Matt
MSHarnett is offline
post #3 of 12 Old 09-29-2003, 02:07 PM
EricsXJ
The Post man
EricsXJ's Avatar
You'll also have to disconnect your vacuum cansiter thats in the passenger side of the bumper.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #4 of 12 Old 09-29-2003, 02:12 PM
MSHarnett
Broke Bogger
MSHarnett's Avatar
Hey Eric, what is that thing anyway. I lost mine so I just plugged the vacuum line. When I got my new bumper I didn't have it secured enough and on the trail it must have popped off. whoops.
Matt
Matt
post #5 of 12 Old 09-29-2003, 02:51 PM
EricsXJ
The Post man
EricsXJ's Avatar
All I know is its needed for your HVAC systems. What it specifically does I do not know.
Eric
My website -
EricsXJ is offline
post #6 of 12 Old 09-29-2003, 02:55 PM
jon campbell
jon campbell's Avatar
That is interesting because I relocated mine into the engine compartment and my air conditioner doesnt get cold. I never got it checked to see why. I am wondering if there is a correlation.
94 XJ 4.0 HO/inline 6 5sp Rusty's 6.5" lift w/ 2" spacers, Rustys steering conversion, RE Control arm drop brackets, RE Hack n Tap SYE, Tom Woods Driveshaft, 33" Tires, 4.56 gears, TJ fender flares, BPI Front winch bumper, CRS rear bumper, K&N air filter, Flowmaster exhaust, M.O.R.E "bomb proof" motor mounts, Surco roof rack
MY PICS
OF...
NORTHEASTCRAWLERS.COM
BLWA.ORG (BLACKLISTWHEELERSASSOC.)
jon campbell is offline
post #7 of 12 Old 09-29-2003, 03:14 PM
erikrs301
Junior Member
erikrs301's Avatar
Matt
6 bolts if you do not have tow hooks from the factory. The factory bumper brackets were welded to the towhook bracket so there were a couple more bolts to pull. Also, soak yer shizz down in PB Blaster before you start torquing on them. Those 13 ytear old bolts will snap off easily if they're rust frozen.
erikrs301 is offline
post #8 of 12 Old 09-29-2003, 03:39 PM
MSHarnett
Broke Bogger
MSHarnett's Avatar
I think that is just a coincidence that this happened at the same time you moved it. You probably need to recharge you ac. I thought my mom's car had a bad compressor when it never got cold, but it turned out in needed to be charged. My friend did it for free, and its a pretty easy task if you don't know what your doing.
Matt
Matt
post #9 of 12 Old 09-29-2003, 03:59 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
And you can even get an A/C conversion kit for around $30 at Walmart or almost any auto store. It's really easy and works as good as R-12.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #10 of 12 Old 03-06-2012, 02:16 PM
andrij13
Matt
i wish it was! i did that, and i couldnt get it to budge! i pulled on it, and hit it with a mallet. it wouldnt not budge! i have some of those cheep hooks on it, which has like a shim bracket thing in between the bumper mounts and the frame rails...
andrij13 is offline
post #11 of 12 Old 03-06-2012, 02:20 PM
andrij13
oh damn. welded?!
thats why i cant get mine off!
i cant remove the tow hook brackets off either, i dont have an allen big enough, and then my steering pump and alternator make it to where i cant fit my socket in there.
andrij13 is offline
post #12 of 12 Old 03-06-2012, 03:11 PM
Azzy
Holy necro post!
Allen wrench?
its probably a torx bolt. I think. Ive never seen the factory setup, but it should just be 3 bolts, that you pull from the bottom. Follow the tow hook back. Should tie into the same holes as the sway bar.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
How to remove rear bumper 98 Cherokee gary1 XJ Cherokee Technical Forum 14 04-11-2012 05:24 PM
New Front Bumper for 89 Jeep Cherokee! hmg2008 XJ Cherokee Technical Forum 4 02-27-2009 03:45 PM
Remove front bumper to install grille guard? white93xj XJ Cherokee Technical Forum 3 11-14-2008 11:20 AM
HELP! Need 2 remove front bumper... JEEPIUS XJ Cherokee Technical Forum 3 11-12-2006 12:47 PM
96 Cherokee front bumper AzzKiker XJ Cherokee Technical Forum 6 11-17-2004 07:43 PM
