How quickly will longer shackles prematurely compress leaf springs? - JeepForum.com
post #1 of 7 Old 12-01-2010, 08:46 PM Thread Starter
andrewmacc
Running a crappy 4.5" Rough Country lift at the moment. And by crappy I mean it's using TJ control arms.
Anyway. I'll be buying a friend's set of 35"x12.5"x15" Mud Countrys off a friend's Ranger. I've trimmed the front pretty extensively (hopefully I'll go all out and have a welder friend help me cut out and re-sheet metal the inner wells for more steering flex clearance), and the rears very soon.
As a little Christmas present, I'm thinking of 2" shackles and 2" coil spacers, just to gain a little clearance a la:
http://www.twiztedengineering.com/se...herokee/Detail
and
(2.25" spacers)
4 Wheel Customs - 2.25" Jeep Coil Spring Spacers (pair)
or
(the 2" poly spacers at the bottom)
Cherokee ACOS, Adjustable Coil Spacer kit
Now, the important question. Will shackles that long prematurely compress my leaf packs to a sad state of sagginess quickly? They seem like a pretty good arch, but will the shackles kill them within a short amount of time or what?
Many thanks in advance.
OH, and extra question: will the 2.25" spacers or the 2" spacers more likely to keep the heep level when used in conjuction with 2" shackles?
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #2 of 7 Old 12-01-2010, 09:14 PM
Holder350
1995 XJ Cherokee
Shackles do not wear springs out.
If you have a lift and have HD springs you could run blocks and be ok, the stock spings are the ones that are flimsy.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 7 Old 12-01-2010, 09:17 PM Thread Starter
andrewmacc
I've heard from many sources that longer shackles will indeed cause leaf spring sag, I just don't know what that timeframe is...?
And you can bet your bottom dollar I'm not running blocks, though!
post #4 of 7 Old 12-01-2010, 09:24 PM
Holder350
1995 XJ Cherokee
How per se would that work? They allow a longer range of travel....but you are not changing the spring rate nor the weight on the spring.
And I dont blame you for not running blocks. I wont even use them on full size trucks.
post #5 of 7 Old 12-01-2010, 09:48 PM Thread Starter
andrewmacc
Hm. Sounds like I should do some research before I open my mouth.. figuratively speaking. I had assumed so because because of the nature of the length of the shackles increasing the angle, they would increase the vertical load on the edge of the leaf spring because the angle focuses the vehicle's mass downward onto the edges of the springs as opposed to spreading it both vertically and horizontally.
Perhaps I'm wrong, then!
Haha, yeah, if the last resort was to block it.. I'd just keep it as is. I have blocks on my full-size on 38"s, but the P.O. did that. Yuck..
post #6 of 7 Old 12-01-2010, 10:54 PM
egodfrey
egodfrey's Avatar
do a shackle relocation braket in the rear and a 1.5 spacer up front....
the shackle relocation braket will boost you 1.5 in the rear and set your shackle at a better angle to get more drop from your springs
HD engineering makes a nice bracket
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #7 of 7 Old 12-02-2010, 02:50 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Longer shackles will sag the stock springs. Good quality lift kit springs will be fine with longer shackles.
Be sure to use longer bump stops, over compressing (inverting) any leaf spring will quickly ruin it.
CJ7-Tim is offline
anyone ever added longer leaf springs to an XJ? underpowered XJ Cherokee Technical Forum 4 09-09-2010 08:00 PM
Anyone with longer shackles 1RustyXJ XJ Cherokee Technical Forum 4 06-13-2010 08:13 PM
RE 4.5 Leaf Springs/ Stock Shackles TreddyoXJ XJ Cherokee Technical Forum 14 06-13-2008 05:26 PM
Longer rear shackles JIMBOJAMES XJ Cherokee Technical Forum 3 02-08-2005 08:04 AM
Longer Shackles=How to modify exhaust? isezumi00 XJ Cherokee Technical Forum 14 01-06-2004 01:28 PM
