How often do you change the TC fluid - JeepForum.com
post #1 of 20 Old 07-06-2010, 09:09 PM Thread Starter
My1989Jeep
1989 XJ Cherokee
I have had my jeep for 5 months and have not changed the transfer case fluid. Don't know if the PO changed it but how often are you suppose to change it?
1st 1989 Jeep Cherokee Laredo. 4 Door. Automatic. 4.0L Straight Six.
My1989Jeep is offline
post #2 of 20 Old 07-06-2010, 09:20 PM
billabongopblue
Not sure what the factory suggests, but i do it about every 30,000 miles. Its not hard nor expensive to do.
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline
post #3 of 20 Old 07-06-2010, 09:25 PM
cumminsjeep24
1997 XJ Cherokee
I do it every year. same with trans fluid. cant hurt. There are two plugs on the back cover of the t case. both use a 10mm allen wrench. the bottom one is the drain, top is the fill. drain it out, replace plug, fill in fill hole until it comes out. it should be about 1.5 quarts of ATF
97XJ 97TJ 11WK2
KCCO
cumminsjeep24 is offline
post #4 of 20 Old 07-06-2010, 09:56 PM
Tex96
---Be sure to loosen the FILL plug FIRST, ---
(ONLY then the drain plug).
Reports of them being difficult to remove some times.
Tex96
Tex96 is offline
post #5 of 20 Old 07-06-2010, 11:03 PM Thread Starter
My1989Jeep
1989 XJ Cherokee
Is there a filter or anything else that needs to be changed, or just the fluid? What fluid do I use D/M III, D/M IV??
post #6 of 20 Old 07-06-2010, 11:47 PM
specialedbob379
1993 XJ Cherokee
2 quarts of d/m 3 would be best, but d/m 4 would be fine. the drain/fill plug on mine was a 1-3/16" or 30mm socket.
1993 Jeep Cherokee Sport - 4.5" RC kit, RC trackbar, Control arm drop, drop pitman arm, IRO Hackn'tap Sye, IRO Exhaust System, 33x12.5x15 Bfg Muds, roof rack
specialedbob379 is offline
post #7 of 20 Old 07-06-2010, 11:56 PM
medicmandan
medicmandan's Avatar
I change mine when I change the tranny fluid.
medicmandan is offline
post #8 of 20 Old 07-07-2010, 12:30 AM
berg
...and don't forget to get a pump thing to get the fluid back in. There isn't much room up there to pour in the fluid.
'98 Sport
RE 3.5 Superflex
32" Maxxis Bighorns
berg is offline
post #9 of 20 Old 07-07-2010, 10:39 AM
XJH-007
XJH-007's Avatar
X2
I'm surprised by how quick the ATF gets dirty.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #10 of 20 Old 07-07-2010, 10:45 AM
gomes512
1994 ZJ
Originally Posted by XJH-007 View Post
X2
Yep dex 3 gets chewed up pretty quick in there. 30K is the interval I use.
BTW it's Dexron 6 not 4
gomes512 is offline
post #11 of 20 Old 07-07-2010, 10:55 AM
gene_82
+1 i change mine every year too..
gene_82 is offline
post #12 of 20 Old 07-07-2010, 12:36 PM
joshrad
1997 XJ Cherokee
So on the 231 in my '98, the fill plug is almost completely rounded out. I was able to pick up a new plug from a junkyard but I haven't attempted to take the fill plug out. When I put the allen wrench in there it fits but I'm afraid that it's going to be stuck and I'll make it worse. Does anyone have any suggestions I can try? I thought of an easy out or reverse drill bit, but I don't think that's a place I should try using either one.
Originally Posted by EJames1226 View Post
Once the members of jeepforum get drunk enough, anyone can be a lawyer.
Originally Posted by Spaz_Soldier
Wait! Does that mean XJs are Xtreme Jeeps?
joshrad is offline
post #13 of 20 Old 07-07-2010, 12:53 PM
xeroOTG
If its a steel plug, weld a nut onto it and remove it with a ratchet.
My jeep gives a whole new meaning to the phrase, Just Empties Every Pocket!
1975 Jeep CJ5 258 TBI EFI, T-18, D-20, D44 rear, 4.11.
1992 Jeep Cherokee 4.0L, AW4, NP231 October 2009 - August 2012
1998 Jeep Cherokee 4.0L, AX15, NP231 - August 2012
xeroOTG is offline
post #14 of 20 Old 07-07-2010, 12:54 PM
XJH-007
XJH-007's Avatar
I would go buy a set of star bits (torx) and find the one that's closest and POUND it in so it fits good and snug.
***02 WJ Overland
XJH-007 is offline
post #15 of 20 Old 07-07-2010, 02:07 PM
joshrad
1997 XJ Cherokee
That's a good idea, I might have to try that.
joshrad is offline
transfercase , transfer , case , fluid , change
Fluid Change XJTrey XJ Cherokee Technical Forum 8 03-22-2010 09:16 PM
Automatic Transmission fluid change, and Transfer Case fluid change questions. MageXX9 XJ Cherokee Technical Forum 4 04-28-2007 06:08 PM
AW4 Fluid Change XxpeditionxJ XJ Cherokee Technical Forum 21 05-19-2006 02:14 PM
fluid change help charlie_merrifi XJ Cherokee Technical Forum 3 12-23-2004 12:57 PM
need really quick help: oil change and ATF fluid change ?'s Ryan31783 XJ Cherokee Technical Forum 6 10-13-2003 01:36 AM
