How much should front wheel bearings cost me?
| SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 | 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
I took my cherokee into a shop today and the guy told me it would be upwards of about 400 dollars for each wheel. They are in pretty bad shape, I have been driving very gingerly.
#2 |
What year XJ? 99/00+ costs a bit more. Last I checked the earlier bearings are just $75
#3 |
I'm assuming that the $400 includes labor. If not, your getting taken.
Mayhem in potentia |
#4 |
It is a 98, I think I need the hubs and all that too. 400-500 on each wheel sounded really steep though.
#5 |
Forum God
i can change out a unitbearing in under 20 minutes probably...sounds like that shop is either pretty incapable of basic work or is running a price up on you.
![]() even with labor added, 400 per side is outrageous. 400 total would make a bit more sense
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me; Thy lift and thy tires, they comfort me. Thou preparest a spotter before me in the presence of mine obstacles; |
#6 |
#7 |
Perhaps it was a matter of miscommunication, I will call him tomorrow and double check. 400 sounds fair for both right and left though?
#8 |
God, you're slow.
I've done it so many times, I've got it down to 10 minutes.But...it wasn't always that way. About 10 years ago when I knew nothing about Jeeps, both of my unit bearings went bad. I had no idea what it was. Stopped by the Midas around the corner, and they gave me an estimate of $600 to replace both. They had me over a barrel. What could I say? Now, it's fun to swap out unit bearings. If anybody local ever needs to replace theirs, I volunteer to do it for a free lunch. |
#9 | |
Forum God
(spacers)
#10 |
Just paid 100 for each hub for my '91.
Local lentz wanted 390 to do both, pep boys wanted 410 to do both.
-HavenSOV Bertha: '91 XJ 4.5 RC, JCR stg 2 Sliders, JCR TC Skid, JCR Stg 3 Rear Bumper, 4.0 HO, Cragar V5's, 31 Dakota M/T, Custom Staff Caring Tubes, Wally World Driving Lights. Kermit: '93, stock right now but will soon have all parts from Bertha. South West Michigan Jeepers |
#11 |
Here's a little write-up, it goes further than you need to.
http://www.greatlakes4x4.com/showthread.php?t=762 This is for a YJ, but they have the same front axle as your XJ. It's really a relatively simple procedure once you get into it.
1998 White ZJ Laredo: 5.2/242 // d30/d44a // BB // MX6's // Black Steelies // 30x9.50x15 BFG A/T's // FM50 // JCR T-Case Skid // Leather and stuff |
#12 |
I paid around a 120 per for my 97 and I did the work myself and saved 300$ and took that money and bought new U- joints for the front. I didn't use and air tools when I did it I didn't want to strip any bolts. Just a breaker bar. I would buy three new bolts for each new hub. and check to make sure that the new bolts fit into the hub before you pay for them. I had one bolt the just didn't fit like the rest. Most likely a freak thing though!! I used a hammer and chisel just worked one conner out at a time and it just came right out. then when you put the new bolts back on it draws into place. And ya I could now do another hub in less time then it would take me to drive to a shop and back .( I am 28 miles away from anything) The first time took awhile but I saved a ton of money doing it myself!
I fond this link this is the one that I used to tell me how to change it http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=257794 Last edited by seth.weed; 05-09-2008 at 08:26 PM.. |
#13 |
![]() And there's a diagram, you just need to replace #6, usually around $100-$150 each at the parts store.
#14 |
He is getting taken if it does include labor!!! $400 per wheel is rediculous.
#15 |
I can see $400 for both sides, as the parts will be around $200 + 10-15% markup + labor at $65 an hour and probably 1.5 hrs per side on the book rate. That's what they go by, and not actual time. Sometimes in your favor, sometimes in theirs.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
