How much play should be in the rear differential gears? - JeepForum.com
post #1 of 7 Old 10-31-2006, 11:57 AM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
I have my rear differential cover off to change the oil and check the gears. I can rotate the drive shaft a good 4-5 degrees before the gears inside the differential start to rotate. Is that bad? If it is I think that's the source the my drive line problems.
*edit: The inside main gear rotates with the driveshaft, however it rotates a bit before stopping (both wheels are on the ground)
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #2 of 7 Old 10-31-2006, 11:58 AM
MrShaft696
I would say no, mine is similar, also what are your driveline issues?
96xj 4.0 5sp 4.5"spartan/aussie locked, 4.56 gears 35"KM2's 98 5.9 zj 4" lift 33's..99 xj 235's
MrShaft696 is offline
post #3 of 7 Old 10-31-2006, 12:04 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
When driving ~40mph+, I let off the throttle, and hit accelerator, there is a huge slam.
-Matt
White '94 YJ Sport
UltimatE is offline
post #4 of 7 Old 10-31-2006, 01:26 PM
JWeb_93YJ
I had this very same problem - and thought it was exactly the same thing. However, I just installed a RE 3.5" SuperRide kit and the SLAM is gone. I didn't touch the gears... only changed shock, leafs, and removed the sway bar. One of those three things was making this noise - perhaps causing "axle wrap" or other loosness? I was surprised that the noise was gone, but something was definitely loose back there.
I know this isn't much help, but maybe it gives you other things to check (bar pins, loose sway bar, weak springs?, etc.) I see you are to install some leaf packs... check your shocks and when you throw the sway bar in the trash, noise might be gone.
JWeb
'93 XJ, 4.0L / 5-speed, 3.5" RE Super-ride on 31s
JWeb_93YJ is offline
post #5 of 7 Old 10-31-2006, 01:40 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Sway bar is already gone.
I'm pretty sure it has something to do with the TC, DS, rear Diff, or the axles. I dunno, maybe it doesn't
-Matt
White '94 YJ Sport
UltimatE is offline
post #6 of 7 Old 11-01-2006, 02:03 AM
shierkahn
I also had a similar clunk. Found out the hard way that it was the pinion bearing that was bad. Didn't figure it out till it totally went out. Try to move the pinion up,down,side to side. if there's play I'd bet the bearings are shot.
'92 XJ, 4" Shade-tree lift
33/12.50's, 15x8 Soft 8's/4"BS
D30ft, D44rr, 3.55 gears
!!GOT MUD!!
shierkahn is offline
post #7 of 7 Old 11-01-2006, 05:32 AM
shmoken875
shmoken875's Avatar
that play is normal
44:4.56, Alloy USA chomos, Yukon Superjoints, Lockrite / 9":4.56, Detroit
Caged/Skided xj on 37s with some other goodies
-Sinking Creek 4wd Association Blacksburg, VA
My 44 Build:
shmoken875 is offline
Rear Driveshaft play? RamboPants XJ Cherokee Technical Forum 3 06-07-2008 10:04 AM
Rear driveshaft play miketyson XJ Cherokee Technical Forum 8 12-07-2007 12:19 AM
93 xj rear axle end play mick ukxj XJ Cherokee Technical Forum 2 10-24-2007 07:24 AM
Play in rear wheels stevenaa XJ Cherokee Technical Forum 4 10-06-2006 06:29 PM
Differential Gear Play Racer X(TCCA) XJ Cherokee Technical Forum 3 05-11-2003 05:46 PM
