How much to overhaul a D44? - JeepForum.com
post #1 of 5 Old 08-16-2007, 10:51 AM Thread Starter
rosader
rosader's Avatar
With stronger shafts, new bearings, 4.88 gears & Eaton E locker?
'98 Jeep Cherokee Sport -Sold-
4.0L I6, auto, 4x4, dana 44 rear, AA SYE, T.W. driveshaft, Custom 5" Lift, 31x12.5 R15 Pro Comp
'02 Isuzu Rodeo Sport
3.2L V6 | automatic | hard top | 4x4
rosader is offline
post #2 of 5 Old 08-16-2007, 10:57 AM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
alloy shafts ~ $300
new bearings ~ $80
4.88 gears/install kit ~$200
eaton e-locker ~ $650
gear setup ~$250
misc stuff ~ $50
total ~ $1500
could be more or less depending on prices
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline
post #3 of 5 Old 08-16-2007, 04:33 PM
sjd78
sjd78's Avatar
I just did mine so I have an idea of cost....
alloy shafts ~ $250 (they come with bearings already)
gear setup ~$250
Fluids/RTV Silicone~ $25
total ~ $1375
Thats if you dont do any brake work or a diff cover.
1998 Cherokee XJ
AW4,NP231 W/SYE & CV Drive Shaft
D30 W/Detroit, Alloy's & 4.88's, D44 W/Detroit, Alloy's & 4.88's
35" BFG M/T's On 15x8 Soft 8's
5.5" T&T/RE Long Arm Lift, T&T Frame Stiffeners, JKS Sway Bar Dico's, RE Monotube's, T&T Steering Box Reinforcement, and much more!
sjd78 is offline
post #4 of 5 Old 08-16-2007, 05:35 PM
Cruzin Illusion
Round Eyed XJ
Cruzin Illusion's Avatar
1987 XJ Cherokee
If you are not set on th E-locker. To get the most strength out of your Dana 44 I would get:
Super 44 Kit with detoit locker $1045.00 or with ARB $1145.00
http://www.ok4wd.com/index.php/catal..._super_44_kit/
Includes: Detroit Locker, 33 Spline axle shafts, Axle Bearings, Backing plates, axle seals, and retainers
Gear set up: (Gears and install kit) $250.00
Gear oil and diffcover sealant: $40.00
So from $1330.00 to $1430.00 you can have one of the strongest dana 44 rear axles without going totally custom and build a 35 splined 44.
Prices can be cheaper if you shop around or ask for a package deal.
30 splined vs. 33 splined
CRUZIN ILLUSION
BUILT NOT BOUGHT
By Cruzin Illusion Customs
View the Cruzin Illusion Rig here:
(OlllllllllllllO)
Rock Frog
CIC's Build Threads:
Cruzin Illusion is offline
post #5 of 5 Old 08-16-2007, 07:27 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Next weak link would be the axle tubes. Simple truss would keep it staright and tighten it up.
Personally for the 33-35's (max 35's) I just want alloy 30 splines and keep my stockers for spares.
Not sure which locker to get. Considering the ECTED.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
steering overhaul tweekedknee XJ Cherokee Technical Forum 5 04-23-2007 08:48 PM
Engine Overhaul sidewinderkid33 XJ Cherokee Technical Forum 19 01-07-2007 05:44 PM
brake overhaul XJ95mlake XJ Cherokee Technical Forum 5 07-12-2006 05:30 AM
UJoint Overhaul midfat XJ Cherokee Technical Forum 1 04-07-2006 06:02 PM
Front End Overhaul dirt machine XJ Cherokee Technical Forum 12 04-07-2006 05:55 PM
