How much more capable are 33s vs 31s? - JeepForum.com
post #1 of 6 Old 10-06-2009, 01:58 PM Thread Starter
djlarroc
1997 XJ Cherokee
I need to buy new tires and am looking to go up in tire size. I'm at 3" and I see going to 33/34x10 is going to require a small fortune besides the tires.
Bigger lift
Fender trimming
Adjustable track bar
GEARING
New carrier
Maybe SYE
Is it worth it? I'm now looking at TSL bias 31x10 (31.3") vs LTB 34x10 (33.6"). Rolling diameter is a bit over 2", but clearance only improves a tad over 1".
Going to 34s is going to run me about $850-1000 more. Is it worth it to those who have done it? The 34s are only about $60 more total. Just all the extra stuff needed to run those.
'97 XJ Country, 3" hybrid, 245/75 MTR, TJ Moabs, Front Truetrac/Rear Aussie, 4:10 gears, skids, recovery.
djlarroc is offline
post #2 of 6 Old 10-06-2009, 02:05 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
you can run 33's on your current lift, thus eliminating the SYE as well. but at 3" you should get an adj. trackbar anyway. gearing and the parts for it are the majority of the cost.
1990JEEPXJ is offline
post #3 of 6 Old 10-06-2009, 02:24 PM
Starboard M
Other then having 1'' more clearance at the diff, and possibly able to get over bigger obsticals, not much.
Is it worth it, depends what your ultimate goal with the Jeep is.
Originally Posted by NoVaHunter View Post
Honestly, its dicks like you that make unnecessary comments via the internet that have no impact what so ever.
Starboard M is offline
post #4 of 6 Old 10-06-2009, 02:35 PM
XJMuscle98
What axles are you running?
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #5 of 6 Old 10-06-2009, 02:38 PM
foggybottombob
I see you are in Denver. In driving Colorado trails, every quarter inch counts. 33's are much more capable than 31's. I can do every line on every obstacle on the wheeler lake trail (except 1) with 33's. You can cut out half of those for 31's.
foggybottombob is offline
post #6 of 6 Old 10-06-2009, 02:50 PM Thread Starter
djlarroc
1997 XJ Cherokee
Thanks. Yeah, I know "is it worth it" is kind of a dumb question to ask, and really only I can decide. I am in CO, and there are alot of rocks.
Currently D30 and 27 sp 8.25. I was going to do the 8.8 w/4:10s and new R&P for front if I went w/34s. Lot's of work to be done to go to 34s.
I've heard that from a few different people. I have only been winched once, on chinaman. I got armor and good recovery points. I did spring creek w/no major troubles. Had to take a few bypasses though.
Just don't know if I should just go w/31s again and put a rear locker and w/the money I save do the x-flex arms and call it done. Or do I start this big project to run 34s. I know it's a personal choice, but am stuck about which way to go.
djlarroc is offline
How capable is this rig? WhiteOut XJ Cherokee Technical Forum 12 08-30-2009 09:52 PM
Building a very capable tow rig...out of an XJ?!?! Bryson XJ Cherokee Technical Forum 66 02-27-2008 12:31 AM
Most capable? Topgun514 XJ Cherokee Technical Forum 10 01-11-2008 12:34 PM
how capable is my jeep? Beeker356 XJ Cherokee Technical Forum 24 11-16-2006 05:59 AM
How capable would a cherokee like this be? JAC83 XJ Cherokee Technical Forum 2 02-14-2006 01:37 PM
