Quantcast How much lift before I HAVE to use SYE - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > How much lift before I HAVE to use SYE
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 01-10-2009, 05:56 PM   #1
x513x
I have a 4.5 inch lift ready to go on my cherokee, but, I also have some 1.5 inch spacers, and 1 inch blocks Id liekt o include, will I be pushing my luck with the driveshaft length? Also, if Its too much lift, can I just stretch my driveshaft? Found a local shop thatll do both the cherokee and my wrangler for 150 lengthened and balanced.
National Topless Day Feb. 3rd 2009!
[url]http://www.jeepforum.com/forum/showt...=652630&page=5[/url]
'93 Wrangler - 2" of lift , 35's , High lift , Murdered out
'97 Cherokee - 4.5 RC lift , 33's , HID's, Murdered out
x513x is offline   Reply With Quote
Old 01-10-2009, 06:01 PM   #2
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
The length of the driveshaft isn't the issue, as much as the angle of the driveshaft. With the 97 model, you will be very lucky to not need the SYE with 4.5" of lift. You will at the least need a transfer case drop with the 4.5" lift, and deffinately need the SYE if you add the blocks and spacers.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 01-10-2009, 07:00 PM   #3
chrisja77
I just put 7" of lift and 35's on my 95 cherokee 2 door. D35/AX15/231 with a 1"TC drop combo. i'm using my stock driveshaft with no vibes. I had it up to 70 today without any issues. I am working on swapping my rear axle now, so we'll see what I need after it's done. I'll put a SYE on it and get rid of the TC drop after I get that done. I have heard the newer models are more prone to vibes though...
USELESS FACTS
111,111,111 X 111,111,111 = 12,345,678,987,654,321
There is a town in Canada named Dildo
The average healthy human farts 16 times a day
To take an oath, ancient Romans put a hand on their testicles. That's where the word testimony comes from
chrisja77 is offline   Reply With Quote
Old 01-10-2009, 07:11 PM   #4
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
The 5 speed, and d35 use a longer driveshaft, than the auto and 8.25. That means you can go higher without vibes. But some of the newer ones will have vibes with a budget boost.
Old 01-10-2009, 08:12 PM   #5
TreddyoXJ
1997 XJ Cherokee
My 97' with 4.5" of lift doesn't have a single vibration problem related to the driveshaft angle. I have a 1" t-case drop on my crossmember, but nothing other than that. I think it's kind of the luck of the draw. I'm planning on upping the lift sometime in the future and will be doing an SYE prior to doing that, but I'm fairly happy with it now.
SOLD: 1997 Jeep Cherokee Country w/ 4.0L HO, AW4, D44, D30 w/ Aussie locker, Edge Trail Jammer System, 4.5" Rough Country lift, Zacatal Roof Rack, T&T front bumper, On board CO2 (20lbs), All lower body/bumpers/trim are Herculined, JKS Disco's, 31x10.5 MT Baja Claws, Warn 9.5ti, Front Rubi 44 in-progress, T&T Customs lift coming soon... Ephesians 6:10-17.
TreddyoXJ is offline   Reply With Quote
Old 01-10-2009, 09:07 PM   #6
x513x
Ok, I do have a t-case drop that came with the kit, whick Ill include, just curious exactly what I should be ready for in the future, thanks for th ehelp again guys!
Old 01-10-2009, 10:02 PM   #7
1996BlackXJ
Well I have just under 3" in the back and I get some vibes with some nasty noises when I let off the gas between 25 and 35mph. I am trying to put together some funds to buy a SYE and then a junkyard front driveshaft.
Auto/8.25 combo
-Max Black 1996 XJ Build Thread: My Maine-iac XJ part deux
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
www.maine4x4.org Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline   Reply With Quote
Old 01-10-2009, 10:15 PM   #8
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I have 3" of lift, and have minor vibes. Saving for RE 4.5" lift, and SYE now.
Old 01-10-2009, 10:46 PM   #9
KevinM90
Right now i have a 96 with aw4/231/8.25, 3" of lift and no vibrations at all really. I am looking to go up to a RC 4.5 lift. I am curious as if i am going to have to save up for an sye before or after i put the lift in
KevinM90 is offline   Reply With Quote
Old 01-11-2009, 10:29 AM   #10
x513x
Heres another newb question, the fornt driveshaft will be fone with the 4.5 inch lift right? The SYE and shaft is needed for the rear only?
Old 01-11-2009, 10:36 AM   #11
thetank
yah the front d shaft will be fine with a 4.5in lift. i just put a 6.5 in lift on my 98 and the front was fine.
thetank is offline   Reply With Quote
Old 01-11-2009, 10:39 AM   #12
Determined2Rise
I just installted the Rough Country 4.5 inch lift with 33x12.5 TSL Radials. The kit came with a tc drop and I have absolutely NO VIBES at all. You should be fine without the SYE. But the SYE and cv driveshaft combo would be a GREAT investment
Determined2Rise is offline   Reply With Quote
Old 01-11-2009, 12:34 PM   #13
x513x
Ok, thats what I wanted to know, I have 32's and the 4.5 kit, and just wanna drive it! If u fit 33's, then I wont bother putting the spacers on it. Thanks again
Old 01-11-2009, 01:00 PM   #14
Determined2Rise
Yeah it rubbed on turns but trimmed the front corners of the flares and fenders. No rubbing now
Old 01-11-2009, 01:09 PM   #15
muddmonky
i just put on a rustys 4.5 and got every bit of 6in and i was about to need a drop pitman arm and a sye but they sayed that after a "relitivly short time" it will break in and level out. im also using a makeshift tc drop kit.
its been a day so far and the vibrations are going away and the stearing is getting better so i guess it just takes a wile.
if you plan on going over 4.5 you might just jeed one not sure though.
muddmonky is offline   Reply With Quote
Glock Forum
