Quantcast How Much Backspacing Is Too Much? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > How Much Backspacing Is Too Much?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 06-02-2009, 07:13 PM   #1
allibaster
2010 JK Wrangler
I'm looking for new wheels for my XJ. Stock backspacing is 5.25" correct? Is 4.0" backspacing too much? Am I going to have bering problems?
allibaster is offline   Reply With Quote
Old 06-02-2009, 07:16 PM   #2
basso4735
1997 XJ Cherokee
4" is good. Stock rims are 5.5" i believe.
Build Thread- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline   Reply With Quote
Old 06-02-2009, 07:18 PM   #3
Mean Max
Mean Max's Avatar
My YJ has 33's mounted on 15X10's with 3.5" of backspace. Dana 30 & Dana 35 axles, and it's been that way for years with no issues.
And my wife's too, same size wheels/tires/backspace. That's not my wife driving BTW, it's our daughter, NOT driving!
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 06-02-2009, 08:08 PM   #4
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
4" backspacing is the recommended size. And 5.25" is stock on the XJ. With the 4" you can run up to 12.50's with no rubbing issues, that is on the lower arms.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 06-02-2009, 09:57 PM   #5
natertots
1990 XJ Cherokee
max thanks for clearing that up about the last pic. Was a little confused.
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline   Reply With Quote
Old 06-02-2009, 10:04 PM   #6
bigbike
1995 XJ Cherokee
I run 3.75 and would even like to go to 3.5
bigbike is offline   Reply With Quote
Old 06-02-2009, 10:19 PM   #7
Mean Max
Mean Max's Avatar
I'm learning how everybody thinks around here........more than 1 person has commented on my "wife" being "awful young" when I've posted that pic of the wife's YJ.
Max
Old 06-02-2009, 10:27 PM   #8
allibaster
2010 JK Wrangler
Haha. I was thinking the same thing when you posted that pic.
My wife hates my Jeep....but that's just too bad. It's a part of the family!
Old 06-02-2009, 10:40 PM   #9
Mean Max
Mean Max's Avatar
We have 3 Jeeps. His & hers YJ's (my '91 her '93) and a '99 WJ for family duty. All 4.0L 4WD.
The 2 young daughters (3 y/o & 9 month old) each have the electric Jeeps.
Max
Old 06-02-2009, 10:50 PM   #10
allibaster
2010 JK Wrangler
That's great! LOL.
Old 06-02-2009, 10:53 PM   #11
allibaster
2010 JK Wrangler
Still have rubbing anywhere else? Any flare trimming?
Old 06-03-2009, 06:45 AM   #12
dcorn
4" will be fine. So you'll be running a 3.5" lift and 30's? Have you trimmed the fenders at all? With my setup, the tires rubbed pretty good on the rear part of the front fender when turning, so I've trimmed quite a bit.
Here is how far mine stick out, but my tires are 11.5" wide.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Old 06-03-2009, 08:36 AM   #13
allibaster
2010 JK Wrangler
I only have 30x9.5s right now. I'll go as big as I can after another 10k miles....
No rubbing, so no trimming yet.
Old 06-03-2009, 10:45 AM   #14
Magus2727
Magus2727's Avatar
1995 XJ Cherokee
I have the side biters on order (they are about 3.75" BS) ans will have 12.5" wide Baja Claws on them. I will post picks let you know how they work when I get the tires mounted and installed. The Rims are on back order.
I have Bushwhackers so I have done some extensive trimming already, but have stock control arms still so we will see if they rub at full lock and if they fit in with the flairs.
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Old 06-03-2009, 01:24 PM   #15
allibaster
2010 JK Wrangler
Just purchased some 15x7 4" bs wheels!
Check em out! Got the black lug nuts, too!
http://www.quadratec.com/products/92613_05XX_B_PG.htm
Glock Forum
