how many bolts hold on the bumper? - JeepForum.com
post #1 of 9 Old 05-04-2008, 06:55 AM Thread Starter
Muddeprived
Muddeprived's Avatar
How many bolts hold on the front bumper of a 2001?
Thanks
Chris
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #2 of 9 Old 05-04-2008, 07:48 AM
dandiv
it should be 6 hexhead bolts holding the mounts onto the unibody, and 4 torx head bolts holding the bumper onto the mount.
if your looking to replace it with a wheelin bumper that wont be enough. your going to want to tie it into your steering box and your frame rails.
dandiv is offline
post #3 of 9 Old 05-04-2008, 07:56 AM Thread Starter
Muddeprived
I needed to know to tell this guy who will be making me a bumper. He wanted to know how many bolts currently hold it and he will triple that. Instead of two brackets, he'll use 6 so it's very strong. I want an indestructable bumper.
post #4 of 9 Old 05-04-2008, 08:28 AM
GP MEHRD
since hes never seen it before its probably a good idea to take it to him with it off so he can get his measurements. less room for error. not a sermon. just a thought.....
GP MEHRD is offline
post #5 of 9 Old 05-04-2008, 08:57 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Have your builder look at this bumper bracket diagram. http://www.twisted-halo.com/digicam/xj/Bumper%20mount.pdf . Some people have said that one of the dimensions is off a little bit but no-one has ever posted which one is off or given any proof. Use the diagram as a starting point. Most of the store bought bumpers use something similar for their mounting brackets.
CJ7-Tim is offline
post #6 of 9 Old 05-09-2008, 04:06 PM
noriegaramon
noriegaramon is offline
post #7 of 9 Old 05-09-2008, 04:19 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Originally Posted by Muddeprived View Post
...He wanted to know how many bolts currently hold it and he will triple that. Instead of two brackets, he'll use 6 so it's very strong....
Um, it doesn't really work that way, and if that's really his logic, I think I'd find a different place to build your bumper.
The factory bumper mounts using 3 bolts per side. Most aftermarket bumpers designed for recovery use these 3 points plus at a minimum the big through-frame hole further back. The rear-most bolt goes completely through the frame.
With 1/4" plate for the brackets, this makes for a pretty strong mounting.
I'd also recommend an L-bracket that ties the front two bumper bolts into the front crossmember:
Many newer bumpers also incorporate the steering box bolts on the driver-side to reinforce that mount, which has proven to be a weak spot on XJs that get wheeled a lot. Something like this, which is similar to the link that CJ7-Tim posted:
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #8 of 9 Old 05-17-2008, 04:13 PM
dandiv
id like to point out that no matter how well your bumper is mounted up, you have a unibody. im not sure what kind of hit the cherokees unibody can take but i really would trust it too well. pple will say there engineered to be real strong but just one look at that sheet metal will tell you otherwise lol. that was a real bummer for me actually i spent 7 months building a rediculasly tough brush guard but it turns out that i cant even really pop anything with it lol.
im not trying to burst your bubble, i figured id warn you though so you dont try and test your bumper at 25 miles an hour lol
dandiv is offline
post #9 of 9 Old 05-17-2008, 05:23 PM
00BlackdOut
Yeah, this doesn't even make sense. Has he ever built anything that will bolt on to an automotive frame before?? Before anybody chimes in, I KNOW it's a unibody. The design hasn't changed since the invention of the auto though.
00BlackdOut is offline
How to get the bolts off that hold the leaf spring ScrnE011 XJ Cherokee Technical Forum 18 02-18-2013 07:31 AM
How many bolts hold tranny to motor? snakester14 XJ Cherokee Technical Forum 5 02-11-2013 09:32 AM
How many bolts hold on a MJ Bed? PitBull4X4 MJ Comanche Technical Forum 3 06-16-2009 09:45 AM
bumper bolts jeep12827 XJ Cherokee Technical Forum 3 07-17-2007 12:14 PM
bolts to hold the nose on ilovjeep XJ Cherokee Technical Forum 1 09-30-2004 10:06 AM
