Quantcast *How-To* LeBaron Hood Vent Install (w/ pics) - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > *How-To* LeBaron Hood Vent Install (w/ pics)
Old 10-11-2007, 09:20 PM   #16
flanker_13
1987 MJ Comanche
I see now the vent sits inside the hole not on top.
Didn't see that at first
I agree the install does look real good.
Not to hijackbut i bought your book Eric. Is a great source of info.
87 Comanche Sportruck
4.0L w/ 5spd.
D30 F/ D35 R
31x10.50-15 stock suspension
flanker_13 is offline   Reply With Quote
Old 10-11-2007, 10:31 PM   #17
lost honda pro
1997 XJ Cherokee
Thanks to everyone for the comments.
As for rain, I'm not worried about it. I've hosed the engine down before, and have had no side effects thus far, so if/when something happens, I will handle it then.
Thanks again to Eric for his great write-up, and obviously the idea for the angle aluminum was key.
lost honda pro is offline   Reply With Quote
Old 10-11-2007, 11:51 PM   #18
cdn_xj
I've returned to the fold
cdn_xj's Avatar
1995 XJ Cherokee
Looks good!
I installed my hood vents as well about a month ago. Fortunately I happend to find white vents and since my XJ is white, did not have to paint them.
About the only recommendations I would add would be:
1) use a jigsaw instead of a cutoff tool (you're less likely to overheat the metal and cause the paint to flake.
2) instead of cutting the angle aluminum into 4 little pieces per vent, I just cut them into one long piece per side. Fewer pieces to muck about with.
cdn_xj is offline   Reply With Quote
Old 10-12-2007, 06:52 AM   #19
lost honda pro
1997 XJ Cherokee
Originally Posted by cdn_xj
Looks good!
Yea, I think body color would look badass, especially if your bumpers/flares are all white too. Got any pics?
1) Except that the jigsaw cuts on the upstroke, whereas the cutoff tool cuts on the downstroke, which I think would yield less flaking (I got none whatsoever). But I also did several lighter passes, versus one long, heavy handed chop.
2) The only problem with that is, unless you round the corners of your aluminum, I would imagine that the straight aluminum being tightened up to a curved surface would leave indents at the two corners where it contacts the hood. Ideally, you want the smallest surface area possible to avoid this from happening, so thats why I went with the small pieces. Plus, its aluminum, so it took all of 4 minutes to chop up all the little pieces and drill the holes. Soft metal is so easy to work with.
Old 10-12-2007, 08:03 AM   #20
trailblaze
how did you get your corners so clean?
just bought a set ( a little more than you paid, but no local JY's had any)
Matt
trailblaze is offline   Reply With Quote
Old 10-12-2007, 08:51 AM   #21
FitchVA
Jeeper 4 Life
FitchVA's Avatar
very nice!
'98 xj sport (trail toy) | specs
'98 xj classic (dd'er) | specs
'89 mj tinker toy | specs
My XJ Page | My Gallery
FitchVA is offline   Reply With Quote
Old 10-12-2007, 12:34 PM   #22
lost honda pro
1997 XJ Cherokee
You mean the corner turn signal lights? I think they may just be reflecting brightly, I've never done anything to em except a regular car wash. Thanks tho
Originally Posted by FitchVA
very nice!
Appreciate it...
Old 10-12-2007, 01:17 PM   #23
trailblaze
umm sorry i should have been more clearer...i meant how did you cut the corners out so clean? did you drill the corners to get the curve there
Matt
Old 10-12-2007, 01:46 PM   #24
lost honda pro
1997 XJ Cherokee
oh, lmao, my bad dude.
i actually used the cutoff wheel for all of it. i did like a 45* cross cut, to connect the two sides, then just rounded the corner with the cutoff wheel. sanded it a little bit, and they turned out pretty good. i actually had to sand two of em back a little, which was good, it just made the vents fit tighter, and tighter is always better
ive heard the drill works well in the corners, but i didnt know how thick the hood was, and i was afraid that it would dent in around the corners, so i just Dremel'd it.
Old 11-05-2007, 06:41 PM   #25
cdn_xj
cdn_xj's Avatar
1995 XJ Cherokee
No pics right now, sorry. Mine's an older XJ sport with the black rockers, grille, bumpers and flares. The body colour vents are great because no one really notices them.
I didn't have any issues with paint flaking at all. In any case, if there's a concern about flaking the paint reverse cut jigsaw blades are available.
I didn't have the patience to do several passes. It took me something like 2 hours to get the first hole done because I was so paranoid about having the hole in the wrong spot & cutting through the hood bracing. I must have measured 5 times! lol
Yeah, I follow what you're saying. I went out and hada close look at my hood. No dents. But then again, I'm one of those people that don't see the point of tightening soething to the point of not being able to lossen it again. lol
Especially since I still need to paint the cut edges of the hood.
'95 XJ Sport 4-dr
4.0 HO - AW4 - NP231 - D30, 4.10, Open - ChrysCo 8.25 29-Spline, 4.10, OEM Trac-Loc
INSTALLED:
2" Carrier Spring custom coils and leafs | BDS shocks | JKS BPEs | 31x10.50-15 Dunlop Radial Rover A/T | 15x7x3.75BS Alloys | RuffStuff Specialties HD Diff Covers | AA SYE | Tom Woods HD driveshaft | LeBaron hood vents | B&M Tranny cooler | Updated badging | Reese Class III Receiver | APN Header | Borla Cat-Back Exhaust | Redline Hood Lift | C4x4 Fab Rear bumper & tire carrier | ORO Licence Plate relocation Kit | Kelley's Works In Progress HD wiring upgrade
TO BE INSTALLED:
Rock Lizard Corner Guards | TnT Customs Unibody Stiffeners | JKS Quicker Discos
PLANNED:
TnT Customs Rock Rails | ARB front Bullbar | Warn 9000lbs Winch | rear disc brakes | TnT Customs 7.5" Y-Link | 33x10.50-15 | 15x8x4.0BS Soft 8 | 4.56 gears | Rusty's flexi flares | 62mm bored TB | Warn Manual Hub Upgrade | JKS ACOS | Rock lights
Old 02-26-2008, 07:34 PM   #26
murrayman23
1987 XJ Cherokee
do you notice your temp guage is a little lower? I saw that some other guy from the UK did some hood vents and he noticed that his temp guage runs lower.
[SIZE="1"][COLOR="Blue"][COLOR="Blue"] [SIZE="3"][COLOR="Lime"][COLOR="White"]"Rusty"[/COLOR][/COLOR][/SIZE] 1987 Jeep Cherokee XJ. 4.0L. 4X4. NP242. 3.5" RE superflex kit. RE Twin Tube Shocks. Rancho RS5000 Steering Stabilizer. Cragar soft 8's. 31" BFGoodrich A/T KO. Warrior Products Rock Crawler Bumper. Cobra CB. Firestik Firefly antenna. KC Daylighters.[COLOR="Black"]Half Herculined[/COLOR] [COLOR="Navy"]Half Navy blue[/COLOR] [/COLOR][/COLOR][/SIZE]
murrayman23 is offline   Reply With Quote
Old 02-26-2008, 10:00 PM   #27
lost honda pro
1997 XJ Cherokee
can't say, but i do see clouds of heat billowing out at low/no speed.
Old 06-17-2009, 02:40 PM   #28
chevyy1212
old thread but still so sweet
chevyy1212 is offline   Reply With Quote
Old 06-18-2009, 02:04 PM   #29
UKJeepThang
I finally did mine a couple of months ago. Love em!!!
1998 XJ
RE 4.5 inch superflex lift, RE GEN2 disconnects, 15x8 Crager 352's, 33x12.5x15 BFG MT, ARB Lockers Front and Rear, 4.56 Diffs, Cut & Tap Short Shaft Conversion, CV Rear Prop, B&M Transmission Cooler and Gauge, Bushwackers Cut-Outs, Skid Row Armor, AJ's SuperRails, LeBaron Hood Vents, KargoMaster Rack, Safari Snorkel, KC Daylighters, Midland CB, Brantz Navigation
Loads a mud!!
UKJeepThang is offline   Reply With Quote
Old 06-18-2009, 02:44 PM   #30
Wrenchands
Wrenchands's Avatar
1995 XJ Cherokee
I made my own. I have to agree it is pretty cool to see the heat pouring out of the hood. Excellent upgrade.
TNT 5.5", 35 x 12.5 MTRs on Trail Ready Beadlocks
Armor: 2x6 inch 3/16 tube rockers, Factory Front and Gas Tank skids, Homemade Mini Skids, Riddler Differential Covers, and Homebrew Hybrid cage.
Recovery: AJs Offroad Custom Front Winch Bumper and Rear Tanker Bumper with Homebrew Tire Carrier/Stinger.
Rhinolined entire Exterior black, and Herculined interior.
Axles: 4.56 superior gears in D30 and 8.25 with 29 spline.
Steering: Currie Extreme and PSC Hydro-assist
Cardomain: http://www.cardomain.com/ride/2973108
Wrenchands is offline   Reply With Quote
Glock Forum
