*How-To* LeBaron Hood Vent Install (w/ pics)
| 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
So, I bought into the hype, found me some LeBaron/New Yorker Turbo Hood Vents, and decided to install 'em. I know there are several write-ups floating around for this install, most notably being EricsXJ.com, which I followed pretty closely (found here http://www.ericsxj.com/vents.htm).
It's pretty straight forward, but patience and meticulousity will ensure a perfect product. 1) Get the vents, sand em, clean em, paint em. I used Rustoleum semi-gloss black, but think I may use Dupli-color's bedliner so they match my bumpers... 2) Lay the vents out on the hood, find out where they need to go to match the hood lines and fit between the hood beams. The beam that goes across the back of the hood (next to the cowl) is kinda deep, so I had to push mine a full 5" forward of the rear of the hood. ![]() 3) I used a total of 3 reinforced (the carbon/kevlar) cut-off discs on my Dremel, just cause I'm ridiculous with a Dremel but then I ended up burning up the motor on the Dremel, so I had to finish it with a jigsaw. Others (including Eric, cited above) have used an angle grinder with excellent results, but I find them too heavy to manipulate accurately. Make sure to cover the engine with something to keep debris off the important stuff.![]() 4) Next, I taped about an 1/8" from the hole, and taped/covered the hood so I could sand the rough edge, clean it, and spray the bare metal to protect from rust. ![]() 5) Give it time to dry, peel the tape, and you're set. It's such a weird feeling seeing what's under the hood from above the hood.... ![]() 6) I used #8 x 1" machine screws with split washers and flat washers to hold the vents down. The metal pieces are 1/2" x 3/4" x 1/16" thick aluminum angle (3 foot piece, chopped to ~1.5") from Home Depot. Clean your hood, and marvel at your own magnificence. ![]() ![]() ![]() Here's the price breakdown: vents - $11.50 from local u-pull-it hardware - ~$4 from Home Depot angle aluminum - ~$5 from Home Depot spray paint - ~$5 from Home Depot reinforced Dremel wheels - ~$7 from Home Depot plus some sandpaper, tape, newspaper/tarp, etc. Total: $32.50
Homebrew Discos- - '01 Intake Install - -S-10 Bastard Pack - -LeBaron Hood Vent Install- - Bored TB - - OE '93 onto '97 Tow Hooks - -Trans Cooler & Temp Gauge Install My Jeep HE15MAN |
#2 |
Junior Member
Wow! Those look awesome! Nice clean work.
jnew |
#3 |
Thanks bro, it actually only took like 4 hours to cut/clean up the holes. Stupid broken Dremel...
#4 |
nice i love cheap mods...
#5 |
what you need to do is take that vent off over the intake and fit a ram air scoop/ vent assembly lol. that would give you like 30+ HP
1996 jeep cherokee se 2 door 5 inch lift rear ended= totaled Rocky Mountain Edition Club member #4 project vehicle new 2002 jetta 1.8t DD |
#6 |
Good write up and good clear pics. I'm waiting for my LeBarons to turn up in the UK. They are mid Atlantic at the moment in a crate with a D44 I'm shipping over here ![]()
1998 XJ RE 4.5 inch superflex lift, RE GEN2 disconnects, 15x8 Crager 352's, 33x12.5x15 BFG MT, ARB Lockers Front and Rear, 4.56 Diffs, Cut & Tap Short Shaft Conversion, CV Rear Prop, B&M Transmission Cooler and Gauge, Bushwackers Cut-Outs, Skid Row Armor, AJ's SuperRails, LeBaron Hood Vents, KargoMaster Rack, Safari Snorkel, KC Daylighters, Midland CB, Brantz Navigation Loads a mud!! |
#7 |
Those look great, but what about rain?
#8 |
what is the point of the hood vents? to help 4.0's run cooler? i always ask myself this question.
( northjerseyjeepclub.org ) 99 cherokee sport auto/231 - RK 3 link long arms, RE 5.5" coils, RC 4.5 leafs w/ RE 1.5" boomerang shackles, RE track bar & bracket, JKS disco's, rustys/RC shocks, P.O.R.C SYE w/ front drive shaft, rugged ridge steering, OR-fab front winch bumper w/ superwinch LP8500, surco roofrack, airflow snorkel, bushwackers & 33" maxxis bighorns . 95 cherokee sport auto np231 - 4.5 RE coils, OME 3 inch full packs, stock track bar ,RE upper and lower control arms, JKS quicker disco's,RC shocks and steering stab.stock tires/rims,t-case from the 99xj, slowly being robbed of all its part before it goes to the JY |
#9 |
Extremly nice work
Looks great!!!!
Lifes A Garden Dig It - Joe Dirt |
#10 |
Need to put alittle black paint on them shiny screwheads....looks good though.
1988 Cherokee 2Dr, 4WD, 4.0 LTR |
#11 | |
Also kind of wondering about the rain issue. I know Eric has some baffles to keep rain off the electronics.
92 YJ 4cyl 5spd 3.5" BDS with 32's on 767's |
#12 | |
Nice write up, and great job. I need to get some vents and do mine now.
-Jeff 1993 XJ Sport, AX15, NP231, D30 open, Chrysler 8.25 open, Rusty's 3" lift with full packs, Firestone Destination A/T 235/75/15's, Uniden PC68XL CB radio, Custom rock sliders, custom intake, trimmed fenders, custom front bumper, 2" receiver front and rear, 48" Hi-Lift jack, OBA. |
#13 |
Just wondering how come you don't cut the hole smaller and use nut-serts to retain the vents instead of clamping them with the aluminum??
Just another way to do it.
87 Comanche Sportruck 4.0L w/ 5spd. D30 F/ D35 R 31x10.50-15 stock suspension |
#14 |
The Guru of Nothing
clean work you did there, nice writeup.
-Kyle
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#15 | |
The Post man
Nice install.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
